Apr 07, 2012, 03:56 PM
Terry Dunn
mopar_man's Avatar
I dusted off my New Moon last weekend and put in several fun flights. We shot some video. It's shaky, but you get the idea.
New Moon EDF (2 min 48 sec)
I took her out again last night and things didn't go quite as well. It was completely my fault. Actually, the damage isn't that bad, but it's time to build anew. She was looking rough.
Any other New Moons taking shape?
Terry
Apr 07, 2012, 04:06 PM
Quad Erat Demonstrandum
scousethief's Avatar
Nice , that is very smart
Jan 27, 2018, 11:43 AM
Sethorus's Avatar
EPP New Moonjet Build
came across this model when ordering some cores from FlyingFoam.
Going with EPP for the fuse and covered balsa for the tail. ordered a cheap 55mm uxcell on 4cell.
fun build so far, goes together quick...
Jan 27, 2018, 11:56 AM
Terry Dunn
mopar_man's Avatar
Awesome! I haven't seen a New Moon in a long time. I have parts to build another. I should do that soon.
Looking forward to watching your progress with it.
Terry
Jan 30, 2018, 12:12 AM
Sethorus's Avatar
added a couple Carbon rods to the wings, and burned out the foam for ducted fan installation
Jan 31, 2018, 10:19 AM
Ft Lauderdale
Number_6's Avatar
Reading all posts about New Moon EDF.
Will scratch build a slightly larger version
since I have 70 and 80 mm EDF units on
the shelf.
Thanks for pics!
A small amount of DIY redesign would
make a nice prop tractor motor plane!!
Jan 31, 2018, 12:43 PM
Sethorus's Avatar
I thought about doing the same thing since I also have a few 64mm lying around(recovered from long destroyed planes), However at 22bucks shipped from Amazon for a 55mm, I figured I'd save a little effort
https://www.amazon.com/uxcell-Blades...ds=uxcell+55mm
Making it from EPP has made mine nearly indestructible!
Jan 31, 2018, 12:54 PM
Ft Lauderdale
Number_6's Avatar
Good deal.
I get a kick out of changing
designs and using what’s in
my shop.
Agree about EPP it is what I prefer.
Hotwiring is fun...sky is the limit.
Feb 01, 2018, 03:18 PM
Sethorus's Avatar
Framed Up
framed up the control surfaces....Ruddervators seem huge, Any reason they were designed this large?
Feb 01, 2018, 03:40 PM
Terry Dunn
mopar_man's Avatar
The tail surface size was originally based on a previous v-tail EDF I had designed and built. Since this design is somewhat short-coupled, I erred towards going larger. Even so, my prototype still had a hint of tail wag coming out of turns.
I made the control surfaces large simply because I wanted the model to have a wide speed range and be aerobatic at all speeds. Some of the most fun I had with my New Moon was with a lightweight setup using a 3S-1300. With that said, it would do pretty good tumbles with the 4S-2200 setup.
Set it up with dual rates and you should be fine. Use the listed throws for high rate and 60-70% for low. I used 30% expo too. But I do that on most of my models.
-Terry
Feb 04, 2018, 03:16 PM
Sethorus's Avatar
Ready to Stuff
yep, she definitely seems short-coupled after getting her together. EPP is pain to cover over, even with a spritz of 3m77. She's a little wrinkly but still looks better than raw foam and will be able to take beating. Ailerons glue hinged with welders.
At this stage, air frame and motor/fan weighs in at 10.1oz(257g)
Edit... pic with another recent build, BD5
Feb 04, 2018, 03:22 PM
Terry Dunn
mopar_man's Avatar
Looks great! Good luck with the maiden flight.
Feb 06, 2018, 04:35 AM
space1
Nice
Feb 22, 2020, 02:44 PM
Jer. 29:11
jeffsch's Avatar
Our club is doing a 150% build of this model. Started a new thread over in the Scratchbuilt EDFs.
www.rcgroups.com/forums/showthread.php?3538539
Apr 11, 2020, 12:21 AM
RaptorMx's Avatar
Plans for New Moon
Hey, I found FlyRC pulled the plans for the New Moon off their website. Is it anywhere else? Where can I get a copy?
Discussion F4D Skyray kit from 6mm FlyRC Lockey Pusher Prop Jet Models 24 Oct 22, 2011 08:02 PM
Discussion Astronauts' tracks, trash seen in new moon photos aerogel Life, The Universe, and Politics 30 Sep 07, 2011 09:56 PM
Discussion Nice Online BVM Electra Article / FlyRC Kevin Murray Electric Ducted Fan Jet Talk 64 Jan 24, 2008 01:28 PM
Discussion New brushless EDF combos - with static trust from 700-1150g - your opinion Ben_E Electric Ducted Fan Jet Talk 9 Jan 11, 2007 10:40 AM
Anyone building the J3 Cub from Flyrc pull out plans? Canada Goose Parkflyers 6 Aug 20, 2004 09:42 PM
