Aug 23, 2012, 06:23 PM
John
jk671's Avatar
Well Mark, here is the results of your handywork! They sound great again thanks a lot.
Freewing SU-35 Build Video #9 Preflight (5 min 37 sec)
Aug 23, 2012, 06:30 PM
The best in EDF since 2005
Extreme_RC's Avatar
Very nice! Looks good finished and sounds pretty good too, cant wait to see the flight video!
Latest blog entry: Extreme RC AUSTRALIA
Aug 23, 2012, 08:07 PM
How close are those trees?
Goody63's Avatar
Nice build (and sound) there.
Good luck with the maiden!!!
Aug 23, 2012, 10:16 PM
John
jk671's Avatar
Hey Mark... Here are my numbers with two working in tandem....
Freewing SU-35 Build Video #10 Wattmeter (3 min 7 sec)
John
jk671's Avatar
Thank you I am looking forward to it!
Aug 24, 2012, 12:32 AM
capt soap's Avatar
Jk, quit teasing us!!! fly it....wan to hear it in the air. Lee
Aug 24, 2012, 08:08 PM
speeddemon
10 blade changesun fan, HET 1W40 5s battery and 100amp esc. would that be a good setup? especially knowing how many amps that motor may draw?
Aug 24, 2012, 10:05 PM
Big motor (in physical ability)... 3300kv..... 5S..... 'attempting' 61K RPM.... more likely reaching 45k to 50k RPM.... it would be interesting to see! LOL
At worst you could go back to 4S if 5S proved it was psycho!
So that combo is going to be at the pointy end of maximums. Make sure it has a battery capable to drive it! (even that item would be a factor in the real end results and limits).
Aug 24, 2012, 11:19 PM
anlucas's Avatar
Not a tried and tested setup on 5S. If you are game in running this you need a beefier ESC. 100amps is not enough. It will probably pull 120+.
Aug 25, 2012, 01:55 AM
John
jk671's Avatar
A few things... First, I apologize for some of the clarity in the video. The lens was a little dirty and was making the focus shift awkwardly...
Secondly, ok now that the negative is out of the way, I have a few things to say about this plane. THIS PLANE IS FREAKING AWESOME!!! The plane is so stable in the air and flies on rails. But man once you kick in the thrust vectoring, it becomes a whole new plane altogether. The possibilities while flying this plane are endless. With a little imagination and a whole lot of practice, I see this plane being, by far, one of the most dynamic edfs to date. Also, my motors are super quiet. I think this might be the quietest setup in a SU-35 video put out on the web to date. But they still have power!!!
For those who are interested, my power setup is as follows:
2 ExtremeRC Alloy Setups, both dynamically balanced by vendor:
2 Changesun 10 Blade 70mm rotors
2 HET 2W-30 Brushless Inrunner Motors
2 ExtremeRC Custom Shaft Adapters and spinners
2 Hobbywing Platinum 100A ESC: Medium Timing
1 CastleCreations 10A UBEC
Turnigy Nano-Tech 6S 5000mah 45C-90C
7 Detrum 9g Servos, 2 Hextronic 19g MG Servos, and 1 T-Pro MG90S(Steering Servo)
Freewing SU-35 Twin 70mm EDF Jet Maiden and 2nd Flights (10 min 20 sec)
Aug 25, 2012, 02:59 AM
Wats the worst that can happen
TheCure's Avatar
Very nice! I applaud all your efforts. It's certainly a beautiful sounding jet. Nicest looking EDF in my opinion too.
You really need to showcase all your efforts and do them justice. Get a decent video camera - or at least turn off that crap auto focus that continually oscillates between blurry and more blurry. A tripod isnt a bad idea too.
anlucas's Avatar
Really nice JK!
That thing really moves.
Funny that when you have a perfectly balanced EDF which is quiet on the bench or in the hands in your case, the motor noise comes through louder when installed in the fuse.
Aug 25, 2012, 03:03 AM
anlucas's Avatar
Here's the maiden of my Dynam ME-262 all stock except the 2 CS10s with Turnigy L2855-2300kv motors on 5S.
I could swear that I thought the fans were quiet when I had them on the stand.
Put them in the nacelles and motor and rotor whine is accentuated. Need to take them off and rebalance them....
Half throttle most of flight. Too dark to fly safely at full speed.
Maiden - Dynam ME-262 with ChangeSun 10 Blade + Turnigy L2855-2300kv motors on 5S (3 min 37 sec)
Aug 25, 2012, 04:16 AM
Goody63's Avatar
http://www.youtube.com/watch?v=JZytzYuC4TA
Hey Andrew
Flew my J-11B with the same exact setup and had the same issue!!
Dynamically balanced both motors and fans (x2) and thought they sounded great.....till I flew it!!
Still pretty quiet but I just think the HK outrunners have their limitations compared to nice HET inrunners.
Speaking of nice setups.......congrats to JK671 on the maiden too!! Nice model!!
Changesun 70MM EDF 10 Blade Powered J-11B and F-16 (3 min 31 sec)
Aug 25, 2012, 04:23 AM
It should fly at least once
clive45's Avatar
Remember you will get some interaction between the 2 fans......usually it changes with throttle change. It the same as twin props unsynchronized
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7700 Aug 29, 2020 05:43 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
