Jan 22, 2012, 04:12 PM
Should've, Would've, Could've
v8truckin's Avatar
1500kv motor running CS 12 blade in my euro. Originally had a 1700kv motor in it but it was pulling 127a & 2709w on my 100a esc setup.
1500kv is now pulling
77a
1780w
Eurofighter Freewing 90mm CS 12 blade (4 min 53 sec)
Jan 22, 2012, 05:37 PM
Nice. 6s,8s???
Steve
Jan 22, 2012, 05:45 PM
v8truckin's Avatar
6s 4000mah, once I charge em later tonight I'll find out how many mah I put back.
Latest blog entry: Freewing Me262
Jan 22, 2012, 05:46 PM
You are a "go" for reentry
Maxthrottle's Avatar
Would anyone like to speculate how a ARC 3655.2 1400kv would do on 8S with the CS90/12? Would it be close to Marks/ExtremeRC HET 1400kv on the same fan?
Jan 22, 2012, 05:48 PM
erh7771's Avatar
I'm thinking 13-1400kv is the 8s rpm motor...
Jan 22, 2012, 05:50 PM
erh7771's Avatar
77a
1780w
Which 1700kv motor did you use?
Jan 22, 2012, 05:51 PM
v8truckin's Avatar
Edf hobbies 1700kv.
vid is 1500kv
Jan 22, 2012, 06:32 PM
? the 3655-2 is a 1400kv motor that is run at 8S. I don't understanding the reply.
Jan 22, 2012, 06:43 PM
Bypass Ratio = Infinity
scatsob's Avatar
I think he meant you should be good to go on 8s with that motor. Do you remember what Mark's numbers were with the HET on 8s? The numbers should be almost identical all things (actually) being equal, especially KV.
Jan 22, 2012, 07:55 PM
The best in EDF since 2005
Extreme_RC's Avatar
3655 is a small can motor, much smaller and lighter than the 700-68-1400, I dont know if I would run it at 100+ amps on 8s.
Latest blog entry: Extreme RC AUSTRALIA
Jan 22, 2012, 09:09 PM
Need helps, my friend has a CS 90mm, with Typhoon 1680kv(the lower one), planning to give it 6S power. Is it a good combination?
Thanks in advance.
Jan 22, 2012, 09:13 PM
Mile High EDF
420flyboy's Avatar
Thanks in advance.
Would be better on 8s
I'm going to use this fan with 1400kv typhoon motor on a 10s
Jan 22, 2012, 09:16 PM
Actually I am not really confident whether it could stand 8s, has another Stumax 90mm will plan to use 10s. And this he choose 6s. is 1680kv too high for 8s?
Extreme_RC's Avatar
Thanks in advance.
It will be fine on 6s, around 100A/2200w. 1400Kv is for 8s setups.
Jan 22, 2012, 09:19 PM
Sniffing the glue
scamair's Avatar
Which 1500kv motor are you using? I have read every page and still don't know which motor to get. Going go in a fly fly hawk on 6cell 5000 pack
Sold Zurich sun blocking sun-glasses $40 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 7 Oct 06, 2011 10:47 PM
Sold Zurich sun blocking sun-glasses $50 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2011 09:14 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Video 6 and 12 blade 90mm fan sound test tom bacsanyi Electric Plane Talk 3 Dec 10, 2009 08:01 PM
