Oct 18, 2011, 06:49 PM
Chinglish-funny
Originally Posted by jkarnacki View Post
My experience also. I really need a filter for my chainlink but I wish I had known the rangelink would be coming out. Sid or Davorz, do you sell an addon LPF for my chainlink or is there any way to "upgrade" from CL to rangelink?
- Jeff
FILTER LOW PASS 600MHZ SMA - CLPFL-0600 - Filters
http://parts.digikey.com/1/parts/194...lpfl-0600.html
http://www.crystek.com/microwave/spe...CLPFL-0600.pdf
GOOD for chainlink;
Sid
Oct 18, 2011, 10:35 PM
I have a chainlink and sunsky 1280MHz tx/rx. I was getting a lot of noise when the chainlink was close to the rx. I replaced the saw filter with one from ready made rc and it made a huge difference. I hardly notice noise any more.
Oct 19, 2011, 04:11 AM
RC pilot by soul
Can you please link to that saw filter ?
is this also the one peope are putting in the Lawmate Rx ?
Oct 19, 2011, 07:52 AM
I have it in Lawmate, you get some extra dB+ with new SAW and this video rx from Sunsky what have inside same SAW dont have problems with interferences
http://www.dpcav.com/xcart/product.p...3&cat=0&page=1
Oct 19, 2011, 08:24 AM
Engineer for Christ
IBCrazy's Avatar
@sid - How are you dealing with packet loss? Do you have a digital check signal to resychronize the system on packet loss? This has been a killer of module based FHSS and causes lock outs. Have you opened up the filter on the RX a bit wider to catch the band extremes or are you relying on the filter to move with the signal to increase sensitivity?
Just curious how this differs from every other LRS out there. Typically it's the implimentation, not the hardware that is the hurdle. What does your latency pattern look like with 20mS packets?
-Alex
Oct 19, 2011, 08:30 AM
Engineer for Christ
IBCrazy's Avatar
Originally Posted by DavorVZ View Post
mate i have tested and this, only on one cheap video rx i get some interference when UHF tx was closer that 1m, only on 1320/1360MHz
on Lawmate is picture cristal clear in all conditions, from 1040-1280MHz
That's simply because of RF swamping. Not out of band noise. The cheap RX's have a weak front end. Ever wonder how they can pick up a video signal clearly on a completely different channel?
I like that the LPF is in the unit. Can you do a 20mS spot capture with an analyzer with the LPF and without? It would be interesting to see how it looks.
-Alex
Oct 19, 2011, 09:23 AM
Balsa addict
Kev.au's Avatar
Sorry if mentioned before.
Can two or more Rangelink systems operate together without any problems?. Has this system been tested alongside other UHF systems?. My brothers DragonLink goes into failsafe when i turn on my EZuhf.
Not looking to start a sh*t fight, just weighing up my options. I want to fly FPV alongside my brother.... that's all.
Cheers, Kev.
Oct 19, 2011, 09:34 AM
Chinglish-funny
Cheers, Kev.
yes, two rangelink can be work fine with together. also support multimaster mode (maybe u need this feature);
blog:
https://www.rcgroups.com/forums/member.php?u=352541
Sid
Oct 19, 2011, 10:37 AM
Cheers, Kev.
o yea, it can work together, i will show you in a hour, video is in upload process
I make short video for MultiMaster Mode, 2 UHF side by side, there is no interferences
Oct 19, 2011, 11:40 AM
MultiMaster Mode in action
RangeLink MultiMaster Mode (1 min 32 sec)
Oct 19, 2011, 11:51 AM
Balsa addict
Kev.au's Avatar
1:30 in that video the servo movement is jittery, my brothers DL does that from time to time, turn power off then on and it goes. It's almost like a computer, needs time to reboot or the fact that the tx sticks are moving while the RL is trying to reconnect.
Or i could be seeing things.
Cheers, Kev.
Oct 19, 2011, 12:10 PM
No mate, i have some bad square connector on Futaba trainer port and it lose PPM out, only this is problem, and servo settings on both rc unit is not identical (trim,reverse) so when i switch from Master1 to Master2 looks like jitter
Oct 19, 2011, 12:25 PM
One more short video, there is no interferences between 2 RangeLink TX, you can fly with brother side by side
RangeLink side by side test (0 min 46 sec)
Oct 19, 2011, 12:37 PM
Balsa addict
Kev.au's Avatar
oh, ok.
Always reassuring seeing a video and not just text. might try and talk my brother into this system.
Cheers, Kev.
Oct 19, 2011, 12:38 PM
fast
fmkit's Avatar
too simple
anyone can switch old 72mhz radios and get the same effect
our receivers track stick position of each transmitter and mix channels - that's MultiMaster.
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 81244 Yesterday 11:59 AM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
New Product ChainLink--The new UHF narrow band long range system BEVRC FPV Talk 878 Jun 08, 2013 06:53 PM
New Product UHF Long range JR / Futaba module Hooks FPV Talk 18 Aug 13, 2012 05:46 AM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
