Dec 24, 2012, 11:50 AM
9W2DLR
Originally Posted by i3dm
Anyone know where Sid went ? im trying to consult him with my low RSSI problem but no response by email for days ??
it xmas everyone is on holiday, you should too , at least he reply my email last friday
Dec 24, 2012, 01:24 PM
USA: LakeGeorge, New York
How is the "filter" on the RL tx?
Will this notch filter be needed? (I'm using 1.2/1.3ghz for Video).
http://www.readymaderc.com/store/ind...oducts_id=1207
Dec 25, 2012, 08:09 AM
Getting RSSI strength on my cyclops easy OSD with Ranglink UHF
Hello everyone,
Hoping someone can help me out with a specific question. I have a Cyclops easy OSD along with a rangelink UHF. I would like to have the RSSI strength on my OSD screen. The rangelink receiver does have a pin for RSSI, so I'm assuming I don't have to open it up and solder anything to that. On my cyclops OSD there is a wire that needs soldered on the RSSI port. My question therefore is connection to the UHF. Basically, Since only 1 wire is being soldered to the OSD, does anyone know which port that should be connected to the rangelink receiver. I'm assuming the signal port, but I'm not sure. Apparently I already have a common ground on the OSD. Anyone with similar components that has done this? Regards, Jess
Dec 25, 2012, 08:37 AM
Originally Posted by Jalee7903
Hello everyone,
I use eagletree but suspect it will be the same. One wire with ferrite ring from signal, (3rd pin on top row) No seperate ground etc.
http://www.google.com/search?q=range...-lr0zzF5hPT7M:
Dec 25, 2012, 10:35 AM
9W2DLR
Hello everyone,
are you sure? last time i check pin 13 is the RSSI out for the RL rx, it even stated in the manual or you have a diffrent version? (if there any?)
Dec 25, 2012, 12:21 PM
What are the "more better features" with the RL compared to EzUHF and DragonLink UHF?
Are the boards very similiar?
There is a huge thread on why my older EzUHF had range issues and 'MANY' failsafes!
(stock antenna, vs Diamond SRH771 Antenna vs
433MHz Nagoya Dual Band Antenna)
The Diamond SRH771 had best results! Is that what you guys use on your RL Tx?
or do you use the Stock Antenna that came with the RL?
I would like your opinions'.....What made you all choose the RL besides the pricing differential.....
Thank You,
HappyHolidays....
Latest blog entry: My FAVORITE FPV CockPits'!!!!
picard10th's Avatar
It is marked on the rx. Signal pin is correct.
Dec 25, 2012, 02:43 PM
Thanks Pathfinder 22, that should do it. Like your pics as well, helps quite a bit. Regards!
Dec 25, 2012, 06:13 PM
Where can i but this set for 100bucks?
Dec 25, 2012, 07:38 PM
Keep an eye on the for sale thread, but I would think these will hold value second for $150 for at least the next couple of months.
Dec 26, 2012, 01:54 AM
picard10th's Avatar
No filter needed!
Dec 26, 2012, 08:32 AM
Thanks picard10th,
I asked because the NEW version2 DragonLink's needs' it from the posts' that Ive read on other threads.
Dec 26, 2012, 08:52 AM
Locko's Avatar
Thanks picard10th,
I asked because the NEW version2 DragonLink's need it from the posts' that Ive read.
Cant go wrong with Rangelink. Awesome product, and cheap. What other LR system sells a rx for $79
Dec 26, 2012, 08:55 AM
I'm most likely going to attach the RL on the new TechPod FPV plane,
http://fpvlab.com/forums/showthread....hlight=techpod
http://hobbyuav.com/
and mount the dipole via rear vertical/horizontal stabilizers,.....
on the RL website, the longes RL Rx antenna is 60cm (~24inches),
http://www.rangepiloting.com/dipole-...0cm-p-181.html
Is it possible to use a DragonLink Rx antenna thats 39"?
http://www.readymaderc.com/store/ind...oducts_id=1063
Or can Sid make me a 39" RL Rx antenna?
Dec 26, 2012, 09:08 AM
I was about to checkOut and buy RL system, but EMS will take 1-2 months?
What happened to 2 weeks at most?
Is the EMS shipping time frame correct?
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 95084 Apr 06, 2024 05:33 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
New Product ChainLink--The new UHF narrow band long range system BEVRC FPV Talk 878 Jun 08, 2013 06:53 PM
New Product UHF Long range JR / Futaba module Hooks FPV Talk 18 Aug 13, 2012 05:46 AM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
