Try using the trainer port to see if you get a signal from there.That will tell you if something else in the radio is fried.
PPM is the combined stream of all your channels together. This output is used by other systems, like the DragonOSD+. |
If my receiver was dead then would the servos still jump a little when I plug them in with throttle attached?
I have two different servos. WHen I plug in the little servos for my pan and tilt camera little G9e servos or whatever. They jump when I connect the battery then there is no power to them. But when I connect my hitec 81 servos. They don't jump when I connect them only once in a while? does this seem right. Still having trouble binding |
I've been careful with ground connections to the right pins and stuff.
I think its because I've been using the wrong channels perhaps. Can someone tell me what are the channel assignments on a DX6i???? I can't find it online? |
1 Throttle 2 Aileron 3 Rudder 4 Elevator |
CH1 thro CH2 aile CH3 elev CH4 rudd CH5 gear |
Thanks!!!
Latest blog entry: www.gunnphotoservices.com
I've tried everything multiple times following the exact instructions and still not binding. I am attempting to bind with both antennas attached both Dragon link RX and TX antennas are attached This is very frustrating
I'm getting really really frustrated because now I hooked the dragon link directly into the DX7. I just linked it up from the 3 wires inside power ppm and ground directly to the dragon link
so that the dragon link turns on when I turn on the controller. Went through the precise rountines to bind. Still nothing!!! I have 2 receivers and I can't bind either of them what the heck could I be doing wrong?? The TX seems to be doing all the right things and the receiver does not bind. thanks for your help!! Adam |
yes I'm getting the green light. Turn the DL TX off unplug the RX.
Then I hold down the (black) botton while I am powering up the DL TX I get a green light flashing. Then I power up the receiver. I wait like 20 seconds. Then I unplug the power to the DL TX. and plug it back it. I get solid green light. nothing from the RX no bind also I'm using a Mono 3.5 plug for the trainer. I thought it should be mono. do you need stereo plug? and I only have ppm and ground going to the plug. Do i need to run the power to the plug I put in the trainer port with a stereo plug??? I can't figure it out!! other people have it working this way with the dx6i I've been through everything!! so stuck |
Thread Tools | |
Similar Threads | |||||
New Product | Long Range UHF RC system now avail on STOCK | thomasscherrer | FPV Equipment | 14517 | Oct 05, 2023 01:13 AM |
Yippee! | Win a FREE Dragon Link UHF Long range RC system - BEST VIDEO contest for AUGUST !!! | JettPilot | FPV Talk | 61 | Aug 01, 2017 05:53 PM |
Wanted | Scherrer UHF long Range or Dragon Link | patrick21x | FPV Equipment (FS/W) | 6 | Dec 24, 2015 04:50 AM |
New Product | ChainLink UHF Long Range System | siim227 | FPV Talk | 2853 | Jul 01, 2013 04:23 PM |
Yippee! | Win a FREE Dragon Link UHF RC System - Video Contest | JettPilot | FPV Talk | 63 | Aug 02, 2011 10:52 PM |
