Nov 30, 2019, 04:12 AM
Hello, Mike.
I wrote you an email several times, but for some reason there is no answer.
A parcel was sent to your address. Answer whether you received it.
Nov 30, 2019, 06:47 AM
Papsi's Avatar
Originally Posted by aticof
I have not managed to connect the bluetooth module HC-05 of the tracker to the internal module Bt of the TxDL. For this reason I connect an HC-05 in the Expansion port with
Do you mean the MFD Crossbow Mini with a HC05 module on the tracker?
Although I get connected to the internal Dragonlink BT module and get now and then data.
Unfortunately, the connection is disconnected every few seconds and the tracker will not turn.
Have now connected to test a HC05 on the EXP port and it works without problems.
Nov 30, 2019, 10:00 AM
aticof's Avatar
I work with OpenTracker360
This is how you comment >> I can connect from the HC05 on tracker to the internal BT of the TxDL SLIM but every 20 seconds it disconnects and reconnects at 5 sec.
Nov 30, 2019, 10:52 AM
JettPilot's Avatar
Originally Posted by Gerryb59
Hey Mike , I have a yagi on my ground station ,what would be a good linear antenna to go on my second diversity receiver to gain some 360* reception ?
Hi GerryB59,
I only use the second antenna for takeoff and landing, or just flying close by. I use a Dragon Link Dipole video transmitter antenna with the long semi rigid coax for this, so I can just bend it vertical above the video receiver. You can also use the vertical antenna that came with your video receiver, since you only use it for very close range.
Nov 30, 2019, 11:00 AM
aticof's Avatar
TxDL SLIM & NO SLIM >>working temperature difference
One question:
I have noticed that the TxDL SLIM at the same supply voltage takes more temperature than the NO SLIM
This is so?
JettPilot's Avatar
Originally Posted by valerabox
Hello, Mike.
Hi Valerabox,
I have not seen it yet. International mail can be a bit slow sometimes.
Nov 30, 2019, 11:03 AM
JettPilot's Avatar
One question:
This is so?
Hi Aticof,
The laws of physics apply to Dragon Link sometimes The same amount of power in an enclosure 1/2 the size will always get warmer. I would not worry about it, as we get exactly zero heat related failures.
Nov 30, 2019, 11:29 AM
aticof's Avatar
Originally Posted by JettPilot
Hi Aticof,
I imagined it but I wanted to make sure
Nov 30, 2019, 11:44 AM
Hi Valerabox,
Please look again
track number shows what has been delivered
RH790399968UA
https://tools.usps.com/go/TrackConfi...790399968UA%2C
Nov 30, 2019, 12:00 PM
aticof's Avatar
Graupner MC-20 & Rx 2,4 repeater or relay
Does anyone work with a Graupner MC-20 and one 2.4 GHz Rx as repeater or relay for the TxDL?
Nov 30, 2019, 01:10 PM
I use MZ -18, MZ-24, and MC-28. They all work fine. Getting the receiver to output PPM is a little tricky. I believe you have to have at least an eight channel receiver or above to make it work, but I could be mistaken.
Nov 30, 2019, 03:51 PM
aticof's Avatar
I have managed to operate one GR-24 as a repeater but I can not refine the FS
Nov 30, 2019, 07:47 PM
I do not understand what you are asking.
Nov 30, 2019, 09:31 PM
JettPilot's Avatar
There are a LOT of possible failsafe setups, depending on the equipment you have. So it is impossible for me to give you specific, easy instructions on how to set the different failsafes of the 3 different devices involved. Dragon Link has 3 settings, Your Graupner probably has 3 or more settings, and your flight controller has even more failsafe options, but lets assume 3 fialsafe options in the flight controller:
3 X 3 X 3 Would mean at least 27 ways you can set your failsafe. You should read and understand failsafe, learn exactly what each setting does, and then start at the beginning and follow each device in the chain and how it will react to a failsafe.
What I can tell you is that the repeater setup works very well, and that you can setup the failsafe to work perfectly
Dec 01, 2019, 01:39 AM
You have to set up failsafe on the throttle value
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14470 Jan 16, 2020 12:39 PM
Yippee! Win a FREE Dragon Link UHF Long range RC system - BEST VIDEO contest for AUGUST !!! JettPilot FPV Talk 61 Aug 01, 2017 05:53 PM
Wanted Scherrer UHF long Range or Dragon Link patrick21x FPV Equipment (FS/W) 6 Dec 24, 2015 04:50 AM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
Yippee! Win a FREE Dragon Link UHF RC System - Video Contest JettPilot FPV Talk 63 Aug 02, 2011 10:52 PM
