Aileron question
I was re-vamping an old plane and had some foam ailerons left over from a different plane. They are quite a bit bigger then my old ones and WOULD work great except one problem, they hang low.
Now I'm thinking that either this will created a "damn" of air and cause drag or it will create a "truck bed" type effect where the air will circulate and provide a surface for the remaining airflow to slide right over. What do you guys think? |
The way you have it will work fine as long as it's not to deep, say 1/8 in. You'll get smooth airflow. Having the ail thinner than the wing will cause a lot of aerodynamic drag comparatively, more like your truckbed turbulance.
Gord. |
Judging from a recent experience... if they stick down very much it will fly like you have a some 'flap' dialed in.
Better to have a smooth transition, if possible, though what you have will certainly 'work' if it's not a ridiculous amount lower. All depends on the plane and how you fly it, whether your results will be acceptable, to be honest. |
It probably won't matter much on the scale we're talking about, but why not just remove the extra material or streamline the lower front?
Thread Tools | |
Similar Threads | |||||
Discussion | Aileron trailing edge question. | GliderJim | 3D / Fun Fly Fuel Planes | 5 | Aug 01, 2011 09:15 AM |
Discussion | Question about aileron servo and suggestions... | Kayayem | Electric Plane Talk | 13 | May 29, 2011 01:17 PM |
Discussion | RCM Trainer 40 Aileron Servo Mount Question | swimmer | Glow to Electric Conversions | 5 | Apr 21, 2011 08:09 PM |
Discussion | Multiplex Minimag - aileron or not to aileron? that is the question | Eiganvalue | Beginner Training Area (Aircraft-Electric) | 9 | Nov 17, 2010 06:12 PM |
To Aileron or Not to Aileron? That is my question! | Keitha | Parkflyers | 14 | Mar 15, 2002 06:19 PM |
