Feb 21, 2020, 09:19 PM
Soar high, huck low
electrich's Avatar
Re- Crack Yak. The entire wing is flat. it does not negatively effect flight at all, and makes assembly a breeze. Many, if not most of the planes Twisted is famous for don’t have an airfoil. I think every pilot should have a Crack Yak. Or 2.
Latest blog entry: Super sized Delta combat wing
Feb 22, 2020, 12:10 AM
Originally Posted by electrich
Re- Crack Yak. The entire wing is flat. it does not negatively effect flight at all, and makes assembly a breeze. Many, if not most of the planes Twisted is famous for donít have an airfoil. I think every pilot should have a Crack Yak. Or 2.
thanks very much for the explanation.
Feb 22, 2020, 08:03 PM
Just wanted to say thanks to Twisted Hobby for the prompt response to an issue I had.Great customer service!
Feb 23, 2020, 01:42 AM
TEAM TWISTED!
Ethan Ater's Avatar
Brand New TwistedHobbys Veloxity Scheme In Action!
Hey Twisted fam!
Figured I'd drop this video right here for you all to enjoy Happy to now be a proud Veloxity owner! This scheme shows up so well in the sky and the performance of this airplane is amazing. The characteristics of a balsa 3D plane with the durability of an EPP plane is something that everyone should have! Anyways, enjoy the video
Twisted Hobbys Veloxity Ethan Ater (4 min 7 sec)
Feb 23, 2020, 08:49 PM
Awesome flying Ethan! Really like your style. Those rifle rolls are looking nice, mine are still a work in progress.....
Feb 23, 2020, 09:59 PM
3D Sunset Flier
Buzzed's Avatar
Yeah! What he ☝️said. Great flyin’ & awesome new scheme.
Feb 26, 2020, 05:55 AM
a_semchenko's Avatar
My new Click-R2
Rc Factory Click-R2 (1 min 25 sec)
Feb 26, 2020, 11:20 AM
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
Very nice! What components are you using on this one?
Cool light kit.
...FYI for anyone looking for LED's, I was pleased to just learn Aurora is still in business but have been battling website issues for months. I am going to get a couple sets of lights.
Feb 27, 2020, 01:46 AM
I use Gening 2xD541BB and D561 servos, Sunnysky X2302-19 kv 1650 V3 motor, Siskin 11A ESC, GWS EP-0843 prop, Turnigy Nanotech 300 mAh 70C acc.
For the lights i use modified 12V LED strips, i cut one of the LEDs in a3-led groop to make it able to operate on 8 V. Then i cut the substrate to remove unnecessary areas and glue with Uhu Por. I use 0,3 mm cuprum wire to connect led strips together.
Feb 27, 2020, 03:14 AM
Originally Posted by a_semchenko
very nice! OHPA!!
Feb 27, 2020, 10:46 AM
I was given a 39" T/H Edge almost ready to go. i needed to get a new motor so i opted for a Sunnysky X2212/980kv V3 (blue) motor. it has a 40A ESC. and the guy i got it from was using a 3s/2200MAH battery. need to buy some props and would like to know what size prop to use. there prop chart goes up to a 10/4.7. i have seen others here say they use up to a 11/4.6D? also what is the difference in a "Regular" Prop and a SLOW FLY?? thanks,Mike.
OK, FORGET The Above. sorry,plane is a 43" EDGE 3. uses 12.6 props,but still would like to know what the difference is with the "SLOW" fly props? ALSO, does anyone know what the spline count is on the ICE 14G servo is?? thanks,mike.
Feb 28, 2020, 12:33 PM
Compulsive battery charger
genix's Avatar
Wow...now that is a small place to fly! You did it very well.
Mar 01, 2020, 09:50 PM
Soar high, huck low
electrich's Avatar
I finally got the 3 W’s to line up. Work, weather, wife. Flew a bunch after a long hiatus. I put the big and little beaver through the wringer. I used a 1500 for my first couple flights on the Big Beaver. Today I switched to an 800 and it’s definitely floatier. The same holds true for the ProXy. I got about 6 flights with the ProXy while using FPV. Good times!
Mar 05, 2020, 08:00 PM
Crack Laser Lite or Super Lite???
Mar 05, 2020, 08:15 PM
Soar high, huck low
electrich's Avatar
If you still have a tendency to crash, the lite is a little more forgiving. If your are looking for ultimate performance, the Crack Laser Pro is amazingly light and stiff. I will never be without a Laser Pro. Iím on my 3rd one since itís release and probably have about 2000 combined flights on them. I am still using all the original electronics, except having only to replace a dead aileron servo after 1500 flights.
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 587 Feb 07, 2018 05:09 PM
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1008 Apr 04, 2017 12:39 PM
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 08:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
