Oct 03, 2011, 10:41 AM
RFJ
RFJ
RFJ's Avatar
Build Log
FROG Build-Off Speedy X3.5
Inspired by Sundancer's build log and enthusiasm for Frog designs I decided to join in the fun of his proposed Frog build-off.
I'm no photographer and just a one finger typist so don't expect anything like George's standard of posts.
Looking at the Frog website my choice was between two little models in the Junior series - Scamp & Speedy. These are essentially the same design with the exception of the wing position. Scamp mid and Speedy low.
The safer option would have been the Scamp so naturally I chose the Speedy
I downloaded the plan and, using the Tileprint program, scaled it up to 3.5 times the original and printed it out. The scale factor was chosen to make best use of standard 36" sheets and results in a span of 40".
Using Profili I chose a Goe 436 - a simple 11% flat bottomed section - and printed out the patterns for the various chord lengths of the elliptical wing.
Next step is to make a kit of parts and collect together the necessary hardware.
Ray
Oct 03, 2011, 01:25 PM
Sic itur ad Astra
sparks59's Avatar
Subscribed!
sparks
Oct 03, 2011, 01:56 PM
I like real wooden aeroplanes!
Sundancer's Avatar
Go for it Ray!
Oct 04, 2011, 05:35 AM
Yak 52's Avatar
Looking forward to it Ray!
Jon
Oct 04, 2011, 06:53 AM
RFJ
RFJ
RFJ's Avatar
Thanks for the encouragement guys
Having cut out most of the parts for the complete model I made a start on the tail surfaces. Since the original was of all sheet construction the enlarged version will have no open structure so these are just cut from 1/8" light quarter grain sheet.
Don't believe anyone who says a tailplane can be made from any old wood as there is little stress on it. Ever since the day I folded a tailplane flying a slope soarer I have used a spar of some description. That's the dark strip at about 1/3 chord and the fin/fuselage key on the fin.
The elevator horn is internal and the hinges 1/4" wide strips of hairy mylar superglued in. Total weight of the parts shown is 1oz.
Ray
Oct 04, 2011, 07:05 AM
Sic itur ad Astra
sparks59's Avatar
Very neat work Ray.
Where does one get hold of 'hairy mylar'?
sparks
Oct 04, 2011, 07:47 AM
RFJ
RFJ
RFJ's Avatar
Sparks,
I use these chaps. Not really hairy I suppose but just mylar with rough paper on each side as used on nearly all ARTFs
They are supplied 1"X3/4" so I cut them into three 1"X 1/4" strips. Punch a couple of holes for the superglue to flow into, angle off each corner to aid insertion (pardon ) and put a pencil mark at half way to show where the hinge line will be. One drop of thin Zap on each side and I guaranttee they will never pull out.
Ray
Oct 05, 2011, 03:39 AM
Sic itur ad Astra
sparks59's Avatar
Thanks for the info. Ray
sparks
Oct 05, 2011, 06:10 AM
RFJ
RFJ
RFJ's Avatar
Next component to be built is the wing. I had considered 1/32" balsa covered foam made as per Rob Millinship's Spitfire wing which I built years ago but I didn't have enough suitable balsa for skinning so it has to be ribs and spars.
The skins are 1/16", ribs 3/32", false leading edge 1/8" and the full depth spar 1/8" with a 1/32" ply dihedral brace. The two curved and tapered strips tacked to the board are the wash out jigs positioned under the trailing edge when adding the top skins.
Edge joining the covering sheet is done with good old balsa cement, cyano for everything else plus epoxy used for the trailing edge join to stiffen it. The leading edge is two strips of 1/8" and the tips soft 1/2". Total weight is 3.8 ozs.
Ray
Oct 05, 2011, 06:24 AM
Sundancer's Avatar
Wow Ray, you are not hanging about. It's a lovely wing shape. I shall have to hustle or you will be finished before the Zephyr.
Oct 05, 2011, 06:48 AM
Yak 52's Avatar
Very nice work. The sheeted wing really keeps the Speedy feel...
Oct 05, 2011, 07:04 AM
Sic itur ad Astra
sparks59's Avatar
Nice work Ray!
sparks
Oct 05, 2011, 12:24 PM
RFJ
RFJ
RFJ's Avatar
Well, like you George I am recently retired, the wife's away visiting friends for a week and the weather is terrible so what else should I be doing
By the way I forgot to mention that the Speedy will be a one piece model hence the big gap between the wing panels. The fuselage will have a slot for the spar and the wing will slide in from below and be glued to the fuselage sides.
Finally, would anyone happen to know what colour the printed balsa scheme was on the original FROG kit (red?)
Ray
Oct 05, 2011, 01:21 PM
Sundancer's Avatar
I did build one fifty-odd years ago Ray and I THINK it was red, or maybe orange, but I couldn't swear to it after all this time as I did build most of them.
Oct 05, 2011, 04:54 PM
SB-28 UK Display Pilot
GeeW's Avatar
On the House of Frog site almost all of the offerings seem to be red or blue so I bet the Speedy would have been one of them? Or use the box art picture for inspiration!
Gordon
Contest Build off for FROG designs October 1st 2011 to April 30th 2012 Sundancer Vintage & Old-Timer Designs 240 Dec 13, 2019 05:19 PM
Build Log 2011 Build-off - Frog Senior Series "Tomtitx2" Sundancer Vintage & Old-Timer Designs 137 Jul 30, 2012 07:26 PM
Build Log FROG build-off Oct 2011 - April 2012; ZEPHYR Sundancer Vintage & Old-Timer Designs 75 Mar 09, 2012 01:49 PM
Build Log 2011 Build Off - RC Rudder Assist Tomboy WhyNot Vintage & Old-Timer Designs 9 Sep 06, 2011 12:29 PM
Discussion SEFF 2011 announced!! April 11-16, 2011 going4speed SEFF 2011 214 Feb 07, 2011 08:11 AM
