Sep 29, 2011, 08:13 PM
Question
Giant Super Sportster Motor?
I just bought a sportster and im looking at getting a gas motor for it..Was thinking about the DLE 30? Any thoughts?
Oct 03, 2011, 12:04 PM
<>< AKA W4BPS
Sportster..
A DLE 30 or a Syssa 30 would be a good combo for the Sportster. Brian
Oct 03, 2011, 08:54 PM
Trees are our enemy
The DLE-30 is well loved. I have never owned one, however I have only heard good things..
Oct 03, 2011, 09:05 PM
Will the DLe30 be enough for the sportster?
Oct 04, 2011, 06:58 AM
ARFs Are Me
TomCrump's Avatar
If it were me, I'd put a G-38 in it.
Oct 04, 2011, 10:21 AM
<>< AKA W4BPS
G38
I had a Sportster with a G38. It was indeed a great combo. Care free, great power, and I did enjoy it greatly. Wish I had kept it more than once. I have a Syssa 30 on hand and thought it would fly it nice as well. Brian
Oct 04, 2011, 03:26 PM
I was looking at the specs for the G-38 at almost 2lbs heavier and it spins the same size prop actually the dle will turn a 20" prop..one thing that i did notice the dle max rev is a 1000 rpm less than the zenoah.. hummm?
Oct 04, 2011, 03:37 PM
<>< AKA W4BPS
weight
Some times the weight of the motor is the deciding factor. A lot of warbirds use/need heavier motors like the G38s to balance properly.. Some models do not.. Brian
Oct 04, 2011, 05:12 PM
kerwin50's Avatar
I have had a G 38 and now own a DLE 30. And the DLE 30 wins hands down.
Oct 04, 2011, 05:22 PM
ARFs Are Me
TomCrump's Avatar
Unless the Giant Sportster is different than the smaller versions, it will need the nose weight.
Oct 04, 2011, 06:01 PM
Im not sure about the nose weight, havent seen any build threads. thats a lot of weight 2 lbs. Thse that have put the g38 in did you add weight? Has anyone put the DLE30 in? Did you have to add alot of nose weight?
Oct 04, 2011, 07:34 PM
ARFs Are Me
TomCrump's Avatar
I'd go to the ARF section, at "The Other Place", and see what they are using.
When I was thinking about getting a Giant Sportster, I followed that thread. There is some good info in it, and is worth reading.
I believe that GP says to use a Fugi 34. It's no lightweight.
Oct 05, 2011, 01:07 AM
kerwin50's Avatar
Yeah if you gotta add alot of weight then I'd go with the G38 with a mag and spring starter and maybe smoke. Good luck
Oct 05, 2011, 04:03 AM
mikmerl's Avatar
I have one that flies great with a RYOBI 30cc w/CDI (converted weed wacker motor).
I got a few some time ago from JAG and they perform very reliably the parts are also very cheap.
Good thing about it is that it is rear induction/rear exhaust so they fit well in slender cowls. I have a second one in a ¼ scale RYAN STA and another in a similarly sized Tiger Moth, both have very narrow cowls.
The engines have performed with complete reliability.
If you a looking for 3D performance then this is not the one however if scale aerobatics are to your flying style then have a look at these humble beauties.
mike
Feb 12, 2012, 07:31 AM
i have a giant super sporster with the g38 ! I plan to replace the g38 with the dle 30 .The g38 is so heavy that I have 500 g in the tail to balance it!!!
And I really think that the dle 30 is more powerfull.
For Sale Giant Super Sportster deerfreak Aircraft - Fuel - Airplanes (FS/W) 6 Apr 20, 2011 06:54 PM
Wanted Giant Super Sportster aluminum landing gear loudbikes Aircraft - Fuel - Airplanes (FS/W) 2 Apr 08, 2011 08:34 PM
Discussion Roto Motor 35Vi on Great Planes Giant Scale Super Sportster Juraj Susovica Giant Scale Airplanes 0 Jul 27, 2010 07:27 PM
Question Giant Super Super Sportster Right Thrust? djmarchand Engines 5 Jul 26, 2008 08:41 AM
Question Giant Super Super Sportster Right Thrust? djmarchand Fuel Plane Talk 1 Jul 24, 2008 03:59 PM
