Jan 17, 2017, 12:31 PM
Hamburger
hamburger's Avatar
Originally Posted by --Oz-- View Post
Increasing timing can help with desync, but it can cost effiency and more heat in motor, so increase slowly and check temps every 30~60 seconds.
FYI, them esc's are sub standard compared to todays stuff.
More info on timing
http://owenduffy.net/rc/tools/bldca.htm
Thank you.
I was hoping for someone remembering how to configure such combination.
OwenD has been very helpful and still is.
Slow progress. Updates to follow
Feb 28, 2017, 08:16 AM
But I had some problem. I installed com0com for virtual serial port. It worked in Win 7 but not in Win 8.1 because the driver are not signed. But I found other software Null Modem Emulator. It works in the same way as com0com and totally supports Windows http://www.eltima.com/products/virtual-null-modem/
Mar 05, 2017, 09:48 PM
Fly No Evil
Multistar OPTO 45a BLHeli 14.9
I just recently flashed 8 Multistar 45a OPTO ESCs with BLHeli 14.9. I used a USBasp and HK's ATMega flashing tool. Since the USBasp wasn't being recognized by avrdude in the Win10 VM -- using BLHeliSuite --, I used avrdude from the command line on my Mac. My command line is as follows:
Code:
avrdude -c usbasp -p m8 -U flash:w:MULTISTAR_45A_MULTI_REV14_9.HEX
Each ESC sung it's song upon completion of flashing. I am able to perform a calibration using a Flysky Rx, and the Multistar 4830 motors appear to spin just fine. I did NOT flash a bootloader; either SK or BLHeli. According to the BLHeli Supported ESCs doc, the Multistar 45a does not support a bootloader on the signal pin. The problem I'm having is that I'm unable to program them.
Neither BLHeliSuite or BLHeli Configurator are able to see the ESCs using Betaflight 3.1.5 passthrough on a Revo. Also, when I power up the ESCs at full throttle, I receive the tone for reading the max throttle, but I never gets the beeps afterwards to program other features. How can I program these ESCs? Must I use the ATmega tool every time? I'm hoping there is a 1-wire solution here. Thanks!
Mar 13, 2017, 05:39 PM
Copterdeluxe 30A what firmware
Hi, I bought those ages ago but have not used them yet but might need some 30A ESCs soon.
They come with SimonK according to the label.
Does anyone know which SimonK FW to install to update those?
I would preferable flash them with BLHeli but can't seem to ID the ESC.
Any help would be appreciated!
Cheers,
Stefan
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Drone Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
