Sep 27, 2011, 01:27 PM
Jab69's Avatar
Canards on a scratchbuilt jet
Hi
I want to build a jet with canards.Must the canards be positionrd slightly higher than the wing?Will I have any problems if I put them in line with the wing?
Sep 27, 2011, 02:52 PM
Jab69's Avatar
Hi.
Will there be any differance by putting them in line with the wing
Sep 27, 2011, 06:42 PM
Can glue better than fly!
I guess it would depend on the design, but i would think it wouldn't make much of a difference. More important is getting the CG in the correct spot, everything else works off that.
Sep 29, 2011, 11:42 PM
RSteel's Avatar
It really depends on how big they are. The bigger they are the more airflow they will divert from the main wing. Alot depends on where the intake is if this was a real jet. THe ef2000 puts the canards on the nose of the aircraft, but the intake is on the bottom like the f16. The Gripen and Rafaels canards are behind the cockpit and more on top of the aircraft cause their intakes are on the sides. On a pusher, it really doesnt matter
Video Blaze Scratchbuilt Jet Tumbler Electric Plane Talk 6 May 13, 2011 03:22 PM
Discussion Help, information on canards talkthetorque Aerial Photography 7 Mar 16, 2008 06:33 AM
Discussion A plane with elevator on the canards only? Bugman Jeff Electric Plane Talk 5 Feb 12, 2008 09:25 PM
Discussion Advice on canards rosco Modeling Science 8 May 16, 2007 01:36 AM
