Maybe have em increase the pitch a lil for speed increase since they are going to be stronger props. This would eleviate them going to a higher kv motor, but keep it low enough for the 85a esc. |
Aros!!!!!!!!! |
More questions for the scale guys !!
1) Was this particular Corsair ever done in the Tri--color scheme ? I don't want to modify the cowl if possible . 2)If not , anyone have a cool scheme suggestion , I currently have the white /gray version , leaning to the Tri Color 3)Update on the interior kit , just got home from traveling adding another vacuum for added pulling power and should have the first pull by Saturday |
LHS sold me some enamel paints so that I can begin working on my Corsair. Should have researched it first. Realized enamel is not good for foam before I started painting.
Ok, for those who have further beautified this warbird, how about some tips for painting ordinance and tank tips? Is it necessary to strip existing paint? Got a few days of heavy winds so it will be a good time for some detail work. |
Enamel is fine for EPO foam which FMS planes are made of. You're all good. See my Corsair in my avatar? Enamel.
Try this link, it might have the answer for your tri color question: http://www.markstyling.com/index.htm http://wp.scn.ru/en/ww2/f/571 |
(....and you know you really want the P-40N, right..."..) |
If you're right (which I do not doubt) , then I have a fine stash of paints to use. |
Latest blog entry: Freewing Me262
I read somewhere that the F4U-4's wheel wells are light grey. I plan on adding this to list. The wheel rims were Light Sea Blue. LHS was out of both so I had to color match.
I've painted probably close to 100 planes in 10 years using enamel. You're all good.
That is true with some foams. But this foam is fine. Test an area that will not be visible and see how it works. Actually, I always test first, then shoot if it is fine.
Thread Tools | |
Similar Threads | |||||
New Product | FMS P-47 1700mm wingspan!!! | HLC SHOP | Electric Warbirds | 3287 | Oct 16, 2023 04:49 PM |
New Product | FMS North American P-51 D Mustang 1700mm (67 inches!!!) | Beltpilot | Electric Warbirds | 13117 | Sep 10, 2023 12:00 PM |
Found | Needed Airfield/FMS F4U Corsair Spare Parts | godofthunder77 | Aircraft - Electric - Airplanes (FS/W) | 3 | Sep 05, 2015 09:55 AM |
Discussion | FMS/Airfield 800mm F4U Corsair | norco kid | Electric Warbirds | 3 | Apr 30, 2011 06:22 PM |
Help! | airfield/FMS F4U Corsair help | kayla95 | Electric Warbirds | 2 | Mar 24, 2011 06:12 PM |
