What I ended up doing was first I moved the link ball all the out on the servo arm (approx
12mm) which increased travel some. Then I used the left and right tail gain adjustments on the basic tab to get full left and right throw. Don't know how its going to react in flight yet. |
ZYX-s2 Set my zero degrees at mid stick and my 12 degrees collective pitch. How do I set the 8 degrees with the software? or do I just do as some suggest and set as much travel as possible without binding?
My first flb was a robird and they had a tab for every process. I'm having a bit of trouble wrapping my head around the zyx-S2 adjustments. I may just be over thinking them. |
On the front screen: Select preset parameter 3d. (don't worry we will tame it down) Lower Main Rotor roll/pitch agility to 30. Lower Tail Rotor Yaw rate L/R to 30. (optional) In the advanced section: Set main rotor roll/pitch D gain to 10. Set main rotor RC Deadband to 15. Set tail rotor deceleration L/R to 50. Set tail rotor RC Deadband to 30. Set tail rotor Tail Compensate Cyclic to Tail to 7 (check direction for this later. May need to be -7) Tx aileron/elevator expo to 40% Tx rudder expo 30% Took it out for it's maiden and she appears to handle quite nicely. |
Hi Guys
Having some trouble with my 550GT, ZYX-S equipped. Did post the question in the 550 thread, so I hope no-one minds my cross posting. So my 550 has been flying very well for quite a while. Suddenly developed a fault. Last but one flight, noticed a slight fore/aft nodding, similar to having too low head speed (it doesn't btw) Last flight, this got worse noticeably during the flight. Ended up with the nodding quite violent, and added a sideways element as well, so the tail, viewed from behind was describing an egg shape. (it is close to Easter, after all). Anyway, can't ind anything mechanical, so I was wondering if it could be the ZYX-S. Anyone experienced similar, or give me some advice as to where start looking. Thanks BL |
Hi all.
I've just bought the tarot zyx s2 with usb dongle from HK. I've spent the last four nights reading trying to find a solution to my problem but this thread is over 12 thousands posts! It'll take ages. I'm using a DX6i and AR6115e rx. With a 4 AA power pack for set up. The rx and gyro are connect using conventional wiring. The rx is bound correctly to the tx. The tx is set up for new model with one servo 90° swash. The end points are extended to 125. If I try to do a tx set up I can't get the 3 LEDs to flash sequentially. Depending on which way I push the aileron I get either the solid blue LED or a flashing yellow LED. If I put a plastic poker in the reset hole it will reset but that's it. Computer set up. I have a WIN8 laptop. I've got both John NZ's FBL and the ZYX app. I can select either COM 3, 4 or 5 depending on what USB port I use. But I have an error 10 message everytime. I believe this is driver issue. I've read Ahamay's post about driver installations. But as I'm not 100% sure with what I'm doing on the system side of my computer I'm reluctant to dive in and make changes. Are there any other alternatives available? I can't buy a programming box online as I'm already under scrutiny with my spending. Thanks in advance for any help. Andrew |
Thread Tools | |
Similar Threads | |||||
Discussion | New ALZRC 3GYS Flybarless System | beenflying | Mini Helis | 644 | Dec 07, 2012 05:44 AM |
Found | Tarot 450 or like, long flybarless feather shafts | TubeBarHeli | Aircraft - Electric - Helis (FS/W) | 2 | Jul 25, 2011 01:13 PM |
For Sale | New Align 3G Flybarless System V2.1 | ptt81 | Aircraft - Electric - Helis (FS/W) | 1 | Jun 06, 2011 04:55 PM |
For Sale | New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system | blueindian | Aircraft - Electric - Helis (FS/W) | 0 | May 31, 2011 06:09 PM |
Discussion | Tarot Flybarless | avengedkevinfold | Electric Heli Talk | 1 | May 04, 2011 04:46 AM |
