This thread is privately moderated by shigetyann, who may elect to delete unwanted replies.
Sep 13, 2011, 07:41 AM
shigetyann's Avatar
Still constructing ICON A5:D
The second big challenge is to refine propeller position.
When I saw my friendís DZ ICON A5, its noise was heavy like a nitro plane.
He suggested that noise is generated when a rotating propeller in high speed closes to tailing edge of a main wing, and a share stress of the air between a propeller and the tailing edge causes pressure gradient.
He moved back the motor 20mm using spacers. He succeeded a good result. The noise was reduced significantly.
Latest blog entry: My Macchi-M67 oing on!
Sep 13, 2011, 08:39 AM
shigetyann's Avatar
To make new motor mount, I took every size. Then I cut out every piece.
While I wait glue firmed up, I hooked up a propeller, a spinner and a collet.
There are few type for three-blade spinner. I couldn't find it. So I decided to use a FSK spinner that has not been cut around.
Sep 30, 2011, 08:34 AM
shigetyann's Avatar
Now, there is a little advantage.
This time, I tried to waterproof around the rudder shaft.
From a junk, I saw the rudder shaft is only supported by two plywood boards.
These boards are only put in dual-partitioning fuselages.
There is no glue around these boards.
This means water can easily get through between dual-partitioning fuselages.
I decided to glue around between the boards and fuselages.
Not to stick the rudder shaft, I made two brass pipes.
And I had finished. I expect this process will be effectual to waterproof.
Help! Phoenix Icon A5 problem zeezee Simulators 2 Sep 12, 2011 01:47 PM
Discussion HobbyKing Icon-A5 for FPV? djdavid60 FPV Talk 7 Jul 13, 2011 03:20 PM
Build Log My decoration seaplane - ICON A5 att0836 Foamies (Scratchbuilt) 3 May 27, 2011 03:43 AM
Sold A488 ICON A5 70" wingspan, EPO, retracts,flaps $75 LPU baddb1 Aircraft - Electric - Airplanes (FS/W) 1 Mar 27, 2011 08:26 PM
