Can you tell us the manufacturer, part number, power handling capacity, sensitivity and frequency response of the speakers used in these videos please? Thanks.
I think 7-8 minutes on moderate power sounds about right. 7 minutes to be safe, 8 minutes to push it a bit but still some power left.
Latest blog entry: Freewing Me262
Oh, and I use 5000 mah and get around 8 minutes with a good amount of power to spare. I had to cut out some foam from the nose, but the plane balances PERFECTLY with that battery. It's the Turnigy 5000 MAH 6s 20c. |
Probably why it gets 8mins.....
Power limited by IR. And "good amount of power to spare" is a relative term, not a measurement of anything concrete - so it could mean "a lot slower than people with 40C or 65C". As long as the 20C isn't running hot, and the plane is flying well for the user, then all is fine. You can often find a sweet spot battery, low cost low C, that all the numbers/result balance out nicely for what you want the plane to do..... and save a lot of money on the batteries then - as long as they ARE truly operating in a good heat area for them to survive. I would still want the numbers to show the WOT current used is 0.75 or less of the battery "capability". eg 5000mAH 20C = 100 Amps in this case... so no more than 75 Amps ever called on. And even nicer is if you have 2x the current leeway - but not by just getting the largest C you can, but by the right value C to achieve that balance in that plane's setup. (eg might need 30C, or just 25C, to achieve that) |
Aaron |
My understanding is IF it is NOT a OPTO....CLIP/dissable/dissable with a servo extension...etc.
but what do I know..... UBEC Info from Headsuprc.com --------------------------------------------------------------------------------------------------------------------------------------------------------------- Special note: If the ESC being used has a built in BEC, that BEC must be disabled when using a UBEC, as you should have only one power source providing power to the receiver. To disable the BEC of an ESC, simply disconnect the red wire on the receiver plug of the ESC. In the picture above, we have added an extension between the ESC and receiver, and we have disconnected the red wire on the extension. If you are certain that your ESC does not have a built in BEC, then do not disconnect the red wire of the receiver plug of the ESC (if it has one). Most ESCs that do not have a built-in BEC say OPTO somewhere on the label. |
Thread Tools | |
Similar Threads | |||||
Sold | NEW FMS 57" P-51 Mustang with upgrades | godofthunder77 | Aircraft - Electric - Airplanes (FS/W) | 11 | Sep 14, 2011 02:55 PM |
Sold | NEW FMS 57" P-51 Mustang with upgrades | godofthunder77 | Aircraft - Fuel - Airplanes (FS/W) | 2 | Sep 04, 2011 01:41 PM |
Sold | FMS/Airfield P-51 Mustang V6 - Newest Version w/ tail retract, nav lights, more: BNF | Roswalt | Aircraft - Electric - Airplanes (FS/W) | 9 | May 25, 2011 11:08 AM |
For Sale | Guillows North American P-51 Mustang | SupaMan | Aircraft - Electric - Airplanes (FS/W) | 0 | Jan 04, 2010 10:38 PM |
For Sale | Guillows North American P-51 Mustang | SupaMan | Aircraft - Fuel - Airplanes (FS/W) | 0 | Jan 04, 2010 10:07 PM |
