NAV lights that are worth seeing
Folks,
I have purchased 5 or 6 different navigation light packages looking for one that is visible. None have come close to these. https://www.rcgroups.com/forums/show...65&postcount=9 The bad news is that Sergey has moved on to other projects/hobbies. Anybody ever seen a set of lights as good as this? Anybody have any idea how to do this kind of work or where I might be able to contract for this kind of work? I really like the idea of scale lighting on aircraft, but the current market offerings are really pitiful. TIA! |
To be Flashy or not only depends on the Leds you decide to use ...
So, it's you to choose ... no one else !!! This one is a bit old ... but nice: http://www.mes-avions-rc.net/video/lighttest1.wmv and timing is ... really scale !!! Alain |
Have you checked out Flytron's light systems? In case you have not: http://www.flytron.com/12-rc-light-systems
Wow those lights were very realistic, I've just started to look at the 4017 decade counter thats used in a simple PPM to PWM circuit, from researchhing that I have found a few LED sequencers with that £0.40 chip, I'll report back when I've done something......
i did that on a 12 inch lazy bee. green and red. not visable in the sunlight, but then again we get 350 days of full sun here.
mostly i went with the cheap leds because i was using 1s 130mah. with better leds, or more of them, its very doable. i was thinking of making some kits for sale. but i dont know the flashing sequence........ |
What I want to try is having a 4017 set for only counting to 5, comntect two strobe LEDs together and to out 1 and out 3 this should give...
Better known as double flash pause, so that I don't acidentanlly end up highjacking this thread I will soon start a thread on using the 4017 an one on hacking cheap toys and cycle lights etc for use as navlights. P.s. How's the mini sub? |
How is this done? I ha d a feeling that some phones were overdriving the LED flash as when I tried to find apps to turn them on permanently to use as a torch people kept saying they would burn out if used for more than a second or two at a time.
Exactly, great question man,
...the equation of the applied "time/watt juction power disipation issue" is much abrevated with very short pulse widths. Thus not heating the LED P-N juction to operate beyond it's maximum temperature, but it heats over the time with power applied, (it's actually very wimpy) and with it operating in CW mode (contuinious wave) it will burn out in less than a second. It's all about the device heating, or "Pd", power dissipation. All that is emitted is not only light, is also heat. Mainly due to the simple fact that LEDs are not 100% efficient. However one could remove (sink) the heat with bi-metal juctions that make voltages when heated (and cool when powered- Peltair effect) and place that energy back on the DC bus, but that's another thread. This tecknieque got the 1st sattelite powered from heated radio active cobalt piles using "thermocouples" that produced millivolts and when connected in series the voltages added up. For a light, like tonight's night flying swarie', I just use the google search page I'm sure that there is an app for a blank white screen~ So now you have received a very brief education in semiconductors! AC theroy is a world away from DC theroy. Switching on & off is the way things are done these days. I hope I answered your question Sir. Best, Doug |
Landing/Navigation Lights Beacon/Strobe Lights Alex. |
Ya, I think they are nice enough for the correct application but I don't think they would quite do the job.
I am pretty happy with these http://www.electrodynam.com/rc/EDR-117/index.shtml |
Those are strongly looking like LUXEON Leds ... taken off their heatsinks ...
Note production of the "diabolo" shaped ones ( sideview lens ) has been stopped. only lambertian and batwing lenses still are in production Also have some search on Ebay : you can find ~15000 mcd 140° 4.8 mm dia leds too for landing lights 380000 mcd 40° 10 mm dia leds exist. Alain |
Thread Tools | |
Similar Threads | |||||
Discussion | NE Bravo Sx -- Nav Lights without opening canopy | PaulGilbert | Micro Helis | 2 | Jul 20, 2011 03:58 PM |
Discussion | close ups on nav lights | Trollefant | Scale Boats | 11 | Apr 08, 2011 11:18 AM |
Discussion | What are the alternatives that really are worth (Futaba x Corona) | framos | 3D Flying | 3 | Sep 08, 2009 12:05 PM |
Discussion | are there any fast/aerobatic slopers for $200 that are worth buying? | kevin sadler | Slope Soaring | 16 | May 26, 2006 10:00 PM |
my Curtek nav lights are here! | eBird | Parkflyers | 10 | Jan 03, 2003 07:22 PM |
