This thread is privately moderated by HyperHelis, who may elect to delete unwanted replies.
Sep 02, 2011, 12:34 PM
HyperHelis's Avatar
Yippee!
Hobbyking Quicksilver
Here is my newest addition the Hobbyking Quicksilver! Honestly I was a little unsure once I started the build. One of the tail to wing plastic pieces were glued on sideways resulting in having to unglue and reglue while trying to not break it and I did No big deal. I re-attached them correctly and wrapped it with kevlar thread, ca'd then painted it black. Now as far as the twin pushrod complaints I just removed one all together. As you can see in the pictures I used basswood carved to fit both sides of the elevator then sanded a basswood filler for the center. Had to notch out the vertical a bit also. I will be using an esky 8g servo for elevator with the rest remaining stock. My packs are turnigy 2s 800mah 20c lipos. The known little chunk of cg weight is no longer needed using this combo. Plane's cg is perfect at a 1/3rd back.
Will get a good video made as soon as this tropical storm moves out!
Sep 30, 2020, 09:49 PM
Mr.Atkins's Avatar
Wow!!!
Wanted HobbyKing Quicksilver Flyboy70 Aircraft - Electric - Airplanes (FS/W) 0 Aug 26, 2011 03:09 PM
Quicksilver timjf Slope Soaring 487 Feb 16, 2011 03:18 AM
Quicksilver timjf Slope Soaring 43 Oct 14, 2005 09:34 PM
Looking for a R/C Ultralight like a Quicksilver. Matt Chester Electric Plane Talk 0 Jun 18, 2004 07:20 AM
Quicksilver Slope Glider For Sale glide Aircraft - Sailplanes (FS/W) 2 Mar 19, 2004 08:41 PM
