Maybe that's why I'm so underwhelmed by the SHP, I though would track a lot better, I haven't flown mine since I got the AJ Yak. I'm not a big fan of the SHP anymore, its collecting dust sitting there as an emergency backup in the case of a crash to my Yak or 42 Slick. |
I have just found out today (on another plane) that I don't like the savox SH 0255 nor the TGY2216 (that really seams to be the same)!
I will replace them with Hitec servos. The SH 0257 seams to be fine, will put them into ailerons as I have some. Do you think the HS 65MG resp. the 5065MG is enough for the tail? Did anybody observe elevator blowback with a 65MG on 6V? |
I have ran several 5065 on 6v and some seem want to wiggle after a while....anybody else? FWI...running for the first time a Savox 255mg in the elevator on my EF 48" edge and so far I like it much better than the 5065. |
Thanks! |
I am curious for why you think the resolution on Savox is not good. I know they would wear out fast but I don't know the resolution problem. What is your radio setup? Thanks.
The resolution is just not as good as it is for the HS85mg. My radio setup: T14SG, FrSky TFR8SB. I do have some problems with that TFR8SB, as it doesn't wan't to run on 6V I run it on 5.5V.
Good to know. However, I don't think comparing 0255 to 85MG is fair, even though on the paper they deliver the same torque, but a smaller servo has its physical limit. I also have observed that my servos will jitter more with some particular RXs. Maybe that's the culprit in your case. |
I will do some ground testing with diferent receivers as I suspect something is wrong with that TFR8SB. I'll tell you what I finde... |
What are your experiances with the ZTW B-Series ESCs? Any BEC anomalies there? The SH0255 still has bad resolution for me. If I move the sticks slowly (and constantly) the surfaces really travel in small jumps. And I really have the arms as short as possible maxed all the travel out... |
uhmmmm, I also want to try Savox to see what all the rave is about...Anyone else experienced the same problem? |
Joe is putting together some instructional Videos to help pay for College expenses.
Let us know what you think. 47 SHP Radio View http://store.payloadz.com/go?id=1808980 |
Thread Tools | |
Similar Threads | |||||
For Sale | 3DHS 47" Extra 300 SHP | rdbell | Aircraft - Electric - Airplanes (FS/W) | 10 | Jul 29, 2013 10:39 PM |
Sold | 3DHS 47" Extra 300 SHP Red Brand New | jdrennen03 | Aircraft - Electric - Airplanes (FS/W) | 2 | Aug 03, 2011 12:11 PM |
Wanted | Looking for the 3DHS 47" Extra 300 SHP - Red | GlockDoc | Aircraft - Electric - Airplanes (FS/W) | 1 | Jul 16, 2011 01:14 PM |
Wanted | 3DHS Red Extra SHP v3 47" Cowl | gms | Aircraft - General - Miscellaneous (FS/W) | 0 | Apr 19, 2011 09:59 PM |
