Aug 26, 2011, 08:19 AM
Video
Snowgoose 20 for 6400
snowgoose 20" for 6400 and similar receivers. 1015 motor with kenway gear box, gws 6/3 prop and 1 cell 240 hyperion.
wing is 1mm front half, top and botom (airfoiled); 2mm rear and elevons; canard, fins and keel are 5mm-paper removed; fuse flat and top 3mm; 1mm cf rods on fuse, canard and pushrods; nose epp foam; uhu por glue. 68 gr auw.
wing has a step in the middle to increase stability and to make structure stiff without cf rods. elevons only. fixed elevator.
there are more videos here: https://www.rcgroups.com/forums/thum...ttach&u=161065
Aug 26, 2011, 12:01 PM
MarksRC's Avatar
Thanks for the video. Very nice! Is that 5mm depron? Do you have any plans?
Aug 26, 2011, 02:04 PM
see more details
thanks. just added details. am working on another version with elevator/ailerons to compare. will show here. then i will show drawings. it's still a work-in-process.
Sep 06, 2011, 03:17 AM
John235's Avatar
Good flights - So smooth and stable. The second video looked to slow down very nicely as though its carrying less weight. Did you only change the power system for the second flight?
Sep 06, 2011, 05:13 AM
trim
thanks.
good eye! i just increased the 'up' trim to ease on the throttle for climb-and then it slowed down too. otherwise same everything.
am still playing with details. and another 1 is ready (waiting for good weather), with moving elevator on the canard instead. the idea is to improve response on up and down signals, trying to do loops-otherwise with canards it's difficult, if not impossible-unless maybe if you have lots of power. let's see how it works.
just added more videos. see post 1.
Sep 06, 2011, 05:52 AM
Watt Waster
Tsavah's Avatar
Snow Goose - Canard Design
Originally Posted by phil alvirez
thanks. ... let's see how it works. just added more videos. see post 1.
Like the design and it did look like a good flyer. Hope others take interest also.
Latest blog entry: Center of Gravity - Airplanes
Video Snowfox 20 canard for 6400 phil alvirez Electric Plane Talk 12 Sep 06, 2011 06:23 PM
Discussion Snowfox 20-swept forward canard for 6400 phil alvirez Scratchbuilt Indoor and Micro Models 3 Aug 23, 2011 05:12 PM
Discussion new hk um parts-are they match for 6400? phil alvirez Radios 18 Jul 11, 2011 02:42 AM
Discussion Classic Elf 20" trainer for 6400 brick phil alvirez Scratchbuilt Indoor and Micro Models 6 Apr 12, 2011 08:00 PM
