Jul 22, 2015, 10:42 PM
I meant to do that
eMoon's Avatar
I charge with a 10Ah lifepo4 battery which can use 80% capacity. Works great as I arrive with flight packs charged and it gives me almost 2 recharges on all of them (four 1300mah 3 cells)
Yours looks like a SLA battery so you should only use 50% of its capacity.
Jul 23, 2015, 03:02 AM
Crash With A Crowd
soupaboy's Avatar
Thanks for that info. I'm rather unsure how to know how much of the capacity I used of the battery. All I have is a voltmeter connected. how would I tell? On my lipos i have a tool telling me my remaining capacity
Edit: just spoke with the company i got it from and the guy said it should be fine to run until the IMax turned off since the IMax b6 turns off at around 11v.
Jul 23, 2015, 11:54 AM
Here's a few pics of my charging setup. 2 4010 Duos and a Meanwell 2kW power supply, with custom made 2 channels balance boards, up to 7 cell and a 10 cell plug for my parallel boards (that I don't use anymore since I have enough channels).
Jul 23, 2015, 08:26 PM
Learning 3D
Potoczak's Avatar
Very nice charging setup..! What case did you use???
Jul 25, 2015, 02:45 PM
Here's the setup I was modifying and testing out this morning. With the larger panel it seems to be capable of around five to six amps charge under the right conditions.
The charger itself is a very dated RC charger from maybe a decade ago. But this setup can supply DC-in to any charger that's okay with ~12V, the voltage can be fine-tuned via a pot inside the metal box.
The fourth photo is an earlier version of the setup using a smaller panel. You can also see the voltage converter outside of the metal enclosure. With the smaller panel, the setup was only capable of charging a battery with around 500mA of current.
Jul 25, 2015, 06:07 PM
RC is great fun!
sleb's Avatar
Access
I like the solar set up. What are you using for the converter?
Jul 25, 2015, 07:04 PM
Originally Posted by sleb
Access
It's a rather dated design based on a LTC1149, works up to 48V and roughly 90% efficient or so.
http://cds.linear.com/docs/en/datasheet/1149fa.pdf
Aug 06, 2015, 12:17 PM
Falafel Flop's Avatar
Those charging stations look excellent! I wish I had the skill or know-how to pull something like that off lol
Aug 06, 2015, 12:38 PM
The ones that my son and I made (although far from the ones that you mentioned immediately above your post) function in a Home Depot plastic tool box. They are much simpler but put all the charging functions in one box. I typically charge via my laptop running the Hyperion software and just have power and balance cables running out to Progressive RC modular charging boards. We typically charge two LIPOs at at time (well, really 4 as we have duplicated charger bixes). Maybe a DC PSU is in our future sometime.
K
Aug 21, 2015, 09:09 AM
556duckvader's Avatar
Has anyone used one of these computer sockets in their portable station?
http://m.ebay.com/itm/Computer-and-A...-/331318044180
Aug 21, 2015, 09:22 AM
ltc
ltc
AMA 97737
ltc's Avatar
Not my preferred AC inlet, but you can use them if you have an IEC AC line cord available. This one is 5A (600W), but you can buy similar ones with higher current ratings (up to 20A depending on connector style)
FWIW, I use these on my charging stations
http://www.amazon.com/gp/product/B00...A3RZSTR96PZ344
Allows use of any standard extension cord and seals when not in use.
My power supplies have low voltage enable switches (no need to switch the incoming AC) and I install circuit breakers (no need to carry fuses)
Aug 21, 2015, 04:58 PM
My son and I use a similar one (from Amazon) in our charging boxes, I think this was it:
http://www.amazon.com/Amico-IEC320-M...ds=iec+320+c14
Haven't had any problems.
K
Show your charging station/table tic Electric Plane Talk 6 Oct 31, 2015 06:32 AM
Help wiring up a portable charging station pdiddyg40 Batteries and Chargers 24 Feb 26, 2015 11:58 PM
Gallery Show off your Foam! Pic Thread. kashalp Foamies (Kits) 0 Aug 18, 2011 12:04 AM
Gallery Show off / List your FPV Multi-rotor Setup BayAreaCrasher Multirotor Drone Talk 10 Aug 17, 2011 03:58 AM
