I noticed that the little battery in the GPS module shows 3V when powered (charging) and 1V when not. Anyone have a link to the right replacement? I will try changing it and see I get a fix any faster. Thanks |
Well at least I have my G-OSD in the mail I was looking through the config.h and found the refresh rate. What have people found as the fastest stable setting? |
1 to 2 htz I believe is the two choices that work ,2htz might take some tweaking to get it right if your not using gps maybe faster then
Chris |
Just an idea for the GPS module...
Adding/upgrading the battery is great! I actually juse installed a 5f super cap on my GPS and it changed everything! The Supercap only lasts about a week when a battery would probably last much longer but I like the size. This isnt for the G-OSD but for the Remzibi/Dragon OSD's GPS modules but it would apply to all Modules.
Here is the result indoors! (cold boot, 4 hours from last use)
The battery or super cap keeps power to the memory so that the GPS remembers its basic data for a faster connection next time.
yup... just like those... I got mine from a Electronics convention when I told the guy id never seen 5f in such a small package. He said "try it your self!" and gave me a few... luckily i had two left when i started FPV
nice im making a conversion kit to make any 1.2-1.3ghz vtx into universal 5.8 style connections and just realized how an extra connector might help connect the osd too
good thing I didnt submit my layout to the manufacture yet https://static.rcgroups.net/forums/a...7-IMG_0059.jpg EDIT Here's the finished product.. |
hi everyone so yes i am here because houston we have a problem , i bougth this version of osd at hobbyking https://www.hobbyking.com/hobbyking/s...rch=mini%20osd
and Iflash with this cl-osd.epp and cl-osd.hex and everything was find with the flashing process using the avr extreme burner but now when i plug everything i see just a circle at my right corner in my lcd screen , so sometime wrong with my wiring or wrong firmware ? battery 1 is my main battery to power the quad in paralell battery 2 is my video tx gps black wire connected but if i unplug it from the receiver there no diference the circle stay there my d8r-xp receiver work because i can give trottle to the esc and motor is turning I also try to other channels but seem no diffrence I don't see any voltage number on my screen only the circle I believe its not the wiring the problem because i see the rth circle please help! |
Thread Tools | |
Similar Threads | |||||
Build Log | Super OSD ($90): Open Source Graphic OSD: Vario, 6xADC, Games, Datalog, Dual Video | tom66 | FPV Equipment | 1928 | May 24, 2014 11:07 AM |
Discussion | Open Source Remote Control System (OSRC) | Gizmoman31 | Radios | 152 | Apr 24, 2012 06:01 PM |
Discussion | Open source OSD for FPV | UFO_MAN | FPV Talk | 75 | Sep 07, 2011 02:03 PM |
Question | Open Source Octo Design Available...Looking for someonw who can cut a copy for me... | Schatham421 | Multirotor Drone Talk | 14 | Apr 12, 2011 05:22 PM |
