Are you using AVR extreme burner? Cause it has some crazy aquardnesses...
Follow this instructions and you'll be Ok: 1. Open the EEP file first using File-->open eeprom, make sure that the file type selection on the bottom right of the window is "eep". 2. Open the HEX file second, using File-->open flash file, make sure file type is "hex". 3. Chose At 88 mega chip 4. Push the BURN button, ignore the error massage about incorect board. Do not use the big yellow "Open" button on the main screen to open the files. I have no idea why, but each time I used it I had problems in the burnning procedure. I don't know why or how all that makes a difference, but I did spent several hours to find out the right way to burn the G osd... This way works, other ways may work as well, but this one for sure. |
Hi guys i was trying to get some info on the mini OSD and found this post from renatoa, basically saying it doubts it will be possible to get my Really wanted arrow home. Right now its on backorder and i was about to pay for it until i found this post.
Should i get it?? My plan is to reflash, and get arrow home for those times i get disoriented . (99.8% of the time ) any info its really appreciated, im ready to buy!! Quote:
Just the same here are the links on how to build (compile) http://code.google.com/p/cl-osd/wiki/CompileProgram and install http://code.google.com/p/cl-osd/wiki/Programming |
abletowinginc, if you are able to successfully flash the mini osd pls let us know im ready to hit the buy button but i have been reading here and HK forums that.
It's the same older OSD rewarmed. The MCU, same used in an ESC, has not enough power and enough refresh speed from GPS to draw an arrow. The GPS is an antique Sirf III, possible manufactured before 2000 year, limited to 4800 baud and 1Hz. Just some warehouse cleaning. so ireally want to know if they are right or is just speculations |
im getting closer have alt showing up but the other values are jibberish letters and numbers that make no sense. have to read more try something else iused this link and loaded these files under dr toms name scroll down yull see a zip file https://www.rcgroups.com/forums/show...490446&page=84
got it using the files i just posted it works on fat sharks hoooooray
man what a pain until u get the right file the wala easy as pie......just have to find the right program for the setup u have thats the whole problem
yes it appears to be the version 2.they wont last once everyone figures out what they are, you cant beat the price \
cool figured it be gone cheap as hell for a full function osd
Thread Tools | |
Similar Threads | |||||
Build Log | Super OSD ($90): Open Source Graphic OSD: Vario, 6xADC, Games, Datalog, Dual Video | tom66 | FPV Equipment | 1928 | May 24, 2014 11:07 AM |
Discussion | Open Source Remote Control System (OSRC) | Gizmoman31 | Radios | 152 | Apr 24, 2012 06:01 PM |
Discussion | Open source OSD for FPV | UFO_MAN | FPV Talk | 75 | Sep 07, 2011 02:03 PM |
Question | Open Source Octo Design Available...Looking for someonw who can cut a copy for me... | Schatham421 | Multirotor Drone Talk | 14 | Apr 12, 2011 05:22 PM |
