Sep 18, 2019, 04:25 PM
Wingnutz
Bill Quantock's Avatar
Mains have stopped retracting...
Hoping someone who knows more than I is still reading this thread...
During a recent tx reprogramming, both main gear retracts stopped working, while the nose gear continues to retract, extend normally.
The wiring harness which feeds the main retracts is fine as it will power other retracts consistently.
Im pretty sure the problem is the retracts themselves.
Is there any way short of replacing them to coax them back to life? Id prefer not to remove them from the model as the servo wires have gotten glued in place and pulling them out is going to damage something. I already have replacement retracts but I really would like to get the old ones working.
Help !
Sep 18, 2019, 05:27 PM
Have you tried using a servo tester.. take the wires from the 3 way connector and check them one by one... If they work and if you have access to an air hose give them a blow as there might be grit or dust jamming the gears..
Sep 19, 2019, 12:15 AM
trroadster's Avatar
Help !
That sounds more like a wiring issue. Check that all your connections are tight and polarity is correct. If you don't have a servo tester take a known good servo and plug it into the retract leads one at a time. If it doesn't work it's the leads. If it does it's the retracts.
Sep 19, 2019, 05:10 AM
Wingnutz
Solved by earlier post
Agedflier and trroadster, thanks. I thought it was a wiring issue too, but don’t think so now. The answer was in this thread...post#11351...Faulty unresponsive Retract fix...it worked! Thanks jiggz! I should have mentioned the retracts sat unused over the summer and I think the micro switches in the retracts just stuck...siezed or whatever.
Sep 19, 2019, 06:45 AM
Griphin's Avatar
A lot of knowledge in this thread for a much beloved model
Sep 19, 2019, 08:45 AM
trroadster's Avatar
All's well that ends well....
Sep 19, 2019, 10:04 AM
HZ Super Cub
Grauwulf's Avatar
It's a fantastic first EDF model!
I have to fly mine as a belly lander because our field is grass and not super smooth, but it's still a blast to fly.
Sep 20, 2019, 09:06 AM
Flying R/C since 1964
kallend's Avatar
I accidentally landed in the grass with gear down. Mains are fine but it pulled the ply nosewheel mount away from the foam.
Has anyone a good method of reinforcing this area?
Sep 20, 2019, 04:55 PM
Dinosaur
condor12's Avatar
I launch mine via a catapault, but also have to contend with a roughish grass/dirt strip. I have left the mains on mine, which I use to keep grass and FOD out of the cheater vent during landing. I abandoned the nosewheel many moons ago, and now fill the whole of the nose area -around the 5S battery and the nosewheel cavity - with expanda foam. This significantly increases damage tolerance to the nose area. I have FoamTac'd a patch of thin aluminium under the nose to resist damage during the landing slide. This arrangement works well for me.
Sep 26, 2019, 02:56 PM
This is a great flyer but the nose wheel set up is bad. Almost every one I've seen, the pull-pull got so sloppy it had no directional control. I wish there is an easy upgrade that uses a pushrod setup.
Sep 26, 2019, 08:09 PM
Vince,,, Start with checking posts #2480 and #5249.. They have modified to use pushrods.. I always check "view attachments" for my information.
Hope this helps..
Oct 11, 2019, 10:25 PM
VEGAS_RC_ACE's Avatar
Wow, I was on the fence... Then I saw this incredible thread! Mine is on its way now. Thanks everyone for this amazing thread!
Build Log DH Vampire FB5 (scratch built) a_glider Scale Kit/Scratch Built 67 Oct 26, 2017 11:04 AM
Build Log Scratchbuild 1200mm W/S Balsa DH Vampire EDF Electriflier Scale Kit/Scratch Built 70 Oct 31, 2016 03:48 PM
Sold RC Factoy De Havilland DH 100 Vampire EDF with GWS fan New $60 shipped USPS CONUS be69ar Aircraft - Electric - Airplanes (FS/W) 4 Dec 14, 2009 02:23 PM
Sold RC Factory De Havilland DH 100 Vampire kit with GWS EDF be69ar Aircraft - Electric - Jets (FS/W) 3 Dec 14, 2009 02:22 PM
Build Log Another edf contest entry- DH 100 Vampire Alistego Scratchbuilt Indoor and Micro Models 18 Jan 26, 2009 03:24 PM
