Aug 12, 2011, 03:40 PM
Snowfox 20-swept forward canard for 6400
Snowfox 20 for 6400 brick and similar; 20"ws pusher canard. larger version of the firefox, approximate proportions. 1015 brushless motor with kenway geabox, gws 6/3 prop. 5mm board foam on wing, canard, fins and keel; 3mm upper and side fuse, 1mm elevons; epp nose; uhu por glue, cf 1mm rods on wing/canard, fuse. 60 gr auw with 1 240 hyperion cell.
when i watched a Firefox flying, i wanted to try 1, but they were not available, so i decided to make 1 with about same proportions, just larger.
i used the 1015 geared, as it is brushless, and therefore will last way longer than using a brushed, as in the pusher version the motor would turn the other way and the brushes would last less. i used different structure and materials dimensions. i am still in the process of tunning it up, playing with cg and trim, but it is a fascinating view. i like pushers, and was not able to develop 1 in this size yet. pics in my blog. hope videos soon.
Aug 23, 2011, 01:02 PM
test flights
at the beginning the cg was at 30mm ahead of the 'v' shaped intersection of the wing and the fillet, like the original firefox. i used a flat 5mm airfoil. flight was funny, as unexpectedly it stalled and fell to a side on its tail.
later, i added a top section from 1mm foam, to form a shape like a clark y airfoil to 50% of the chord, and a step. see the type of airfoil here: https://www.rcgroups.com/forums/show...1397047&page=2 (post 21) similar, except that this 1 has a flat bottom.
i still was experiencing the same situation. then i enlarged the canard. but it was not until i began to move the cg forward that the plane became fully controllable. it balances now at the tips of the wings-some 20mm forward. it flies slowly and if stop the motor, it glides nicely. i have not tried any stunts yet. and the 1015 geared brushless performs beautifully. now with the extra ballast, auw is 77 g, that the motor/gb still handles well. still, i think that if i have to build another, i better make a longer reinforced nose so it balances as needed and i don't have to add extra weight.
Aug 23, 2011, 03:43 PM
I R Irv's Avatar
Phil what was your solution for elevons with the 6400?
TODD
Aug 23, 2011, 05:12 PM
vtail mix
TODD
am using v tail mix and it works straightforward when connecting the pushrods directly and not crossed (as i was doing before).
but now i still have the challenge of learning about the hk rx that needs a module and a remote, and now they released another rx that does not need a module/remote. so much to test!
Build Log The Frog - lifting body with canard and forward swept wing (Plans) mardimardigras Foamies (Scratchbuilt) 28 Aug 19, 2013 10:29 AM
Discussion canard w/ sweep forward wing for 6400 phil alvirez Scratchbuilt Indoor and Micro Models 31 Oct 08, 2011 04:05 AM
Build Log Forward Swept Wing with functional canard project BlueFielder Foamies (Scratchbuilt) 12 Jan 04, 2008 01:56 PM
forward swept wing / canard kevin Foamies (Kits) 2 Feb 14, 2003 09:10 AM
