Night Flying at NEAT!!! - Page 3 - RC Groups
Aug 31, 2011, 12:32 AM
heres one of mine that i just set up. its a hobby king yak epp
Sep 06, 2011, 03:03 PM
Head NEAT geek
Tom Hunt's Avatar
Saturday Night slow flyer contest rules
https://www.rcgroups.com/forums/show...17&postcount=7
Sep 06, 2011, 08:22 PM
AMA 504253 Born in the USA
Yellowspider's Avatar
got it now if I can only get the ba--s to do it. Have to weigh my fun cub it might just be to heavy anyways.
Dave
Sep 08, 2011, 08:10 PM
Fast and getting faster!
Hey question for all you night flyers out there, the LED tape, can that handle more than 12 Volts??? Like say a 4 cell???
Sep 08, 2011, 09:29 PM
Petefoss's Avatar
Whew, that might let out the magic smoke since they work quite well on 2S. I would cut off a strip of three and give it a shot. If it smokes them is was only 3 not a strip. Since they are in parallel it's a good test.
Pete
Sep 08, 2011, 11:26 PM
SnarkyMcSnarkson's Avatar
I've never seen a strip that supports more than 12V. You could lower the voltage by running a few diodes. Better than that, get a small 3 cell battery only for the lights if you have the space available.
Sep 08, 2011, 11:28 PM
Hooper, full throttle!
Tommy D's Avatar
Castle Creations BEC works great as a light driver.
Sep 09, 2011, 12:28 PM
A small 2 or 3 cell lipo and CC BEC are good ideas. You could also tap into the balance plug to get 2 cells for one set of lights, and the other 2 cells for a 2nd set of lights...but you'd need to cut off the connector to add wires in parallel or find/buy the mating connector.
Sep 09, 2011, 12:29 PM
Rt 88 is also closed somewhere ("both I-88 East and I-88 West have been closed in Chenango Valley near Binghamton.")...surely not for long though...
Sep 09, 2011, 01:26 PM
Can I run a castle bec in line with the lights to drop the voltage from the battery to the lights without dropping the voltage to the controller?? Basically make a jumper with the castle bec in line ??
Sep 09, 2011, 01:37 PM
Hey Al,
I've essentially done the same thing when I feed my Dimension lighting controller. I think that's a nice simple way of accomodating this if you have the BEC handy.
Rob
Sep 09, 2011, 02:56 PM
Most BECs only provide 5V-6V. These light strips are looking for 12V so I doubt they will work well. The Castle Creations BEC only goes to 9V, but the CC Pro BEC will do 12.5V. The BEC Pro goes for $45 on their site. I'd go with a separate battery before shelling out that type of cash.
Sep 09, 2011, 03:07 PM
Good point. I don't use LED strips - I still use discrete LEDs, where I use a nominal 5V input and use dropping resistors to get the final voltage and set current limits.
Rob
Sep 09, 2011, 03:54 PM
Tommy D's Avatar
@ 12v I find many of the birds people are now flying too Damn bright! Have some consideration for your fellow pilots and try not to blind them!
Sep 09, 2011, 04:06 PM
Tommy,
EXCELLENT point! I know I was blinded a few times last year by planes that were plastered with surface mounted LEDs running at full brightness. Thankfully lots of guys have started using speed controllers to modulate the brightness - goes a long way to making them easier to deal with when they fly into your line of sight!
Rob
Discussion Indoor Night at the NEAT Fair! Saturday September 17th. Joe Malinchak The 2011 NEAT Fair 36 Oct 20, 2011 06:51 AM
Video flying at night alexedit Electric Plane Talk 0 May 12, 2011 05:58 PM
Who all is going to be Night Flying at The NEAT FAIR??? Ryan Nau Electric Plane Talk 10 Aug 31, 2007 03:59 PM
Indoor Night at NEAT 2005 Gordon Johnson Scratchbuilt Indoor and Micro Models 12 Aug 28, 2005 08:51 AM
Indoor Night at NEAT 2003 Gordon Johnson Scratchbuilt Indoor and Micro Models 9 Jun 30, 2003 08:41 PM
