Aug 08, 2011, 03:22 AM
FC flux'd
Katch's Avatar
MultiWii Conf GUI in Linux
Ok I know I'm being thick but how do you install/run the GUI under Linux. I just can't get it running.
Ubuntu 11.04
Aug 08, 2011, 03:33 AM
FC flux'd
Katch's Avatar
Ignore, being dumb - just needed to update the permissions to make it executable.
New problem can't get the Com port to work. I get TTYUSB2, TTYUSB1, TTYUSB0 but in the Arduino software the Com port it uses is called TTYACM0.
Any ideas?
Aug 08, 2011, 03:58 AM
FC flux'd
Katch's Avatar
GUI also appears to hang when moving between the three USB TTYs. It exhibits this behaviour even when the multiwii is disconnected and only the FTDI is plugged in.
Aug 23, 2011, 08:06 AM
Fabio Varesano
fax8's Avatar
Add a symbolic link from ttyACM0 to ttyUSB9 or something and multiwii will discover it.
You may wanna implement something like this automatically with udev:
Code:
[[email protected] ~]$ more /etc/udev/rules.d/09-arduino.rules
SUBSYSTEMS=="usb", ATTRS{product}=="FT232R USB UART", ATTRS{idProduct}=="6001", ATTRS{idVendor}=="0403", SYMLINK+="arduino arduino_$attr{serial} ttyUSB9"
KERNEL=="ttyACM*", ATTRS{product}=="Arduino*", SYMLINK+="arduino arduino_$attr{serial} ttyUSB9"
KERNEL=="rfcomm0", SYMLINK+="arduino ttyUSB9"
The above code will let you connect your Arduino Duemilanove or Arduino Pro Mini + FTDI breakout as well as Arduino UNO and bluetooth serial connection (eg: bluetooth mate gold/silver) always using ttyUSB9.
Aug 30, 2011, 04:12 AM
FC flux'd
Katch's Avatar
Code:
That did the trick - thanks Fabio.
Aug 30, 2011, 04:25 AM
Fabio Varesano
fax8's Avatar
Awesome! Glad it helped.
Aug 30, 2011, 04:34 AM
FC flux'd
Katch's Avatar
Quick question. Is the rfcomm0 at the end to link your bluetooth device?
EDIT - reads your actual post properly. Yes it does. Another thank you.
Aug 30, 2011, 04:44 AM
Fabio Varesano
fax8's Avatar
Yeah, when you use rfcomm to connect to it. Refer to http://www.gentoo.org/doc/en/bluetooth-guide.xml for more informations.
Mar 19, 2013, 07:18 AM
Hi!
Sorry for the old thread reply but I could not find it anywhere and I think it will help.
After a lot of try and error I run MultiWiiConf as root and USB port appears. No need for symbolik link or script.
Code:
$ cd MultiWiiConf/application.linux64
$ sudo ./MultiWiiConf
May 12, 2013, 06:08 AM
I'm a linux noob. wanted to setup a netbook for multiwii gui
downloadet the files.
but i have no idea how to install them ??
ubuntu 12,10
Mar 13, 2014, 09:21 PM
I tested on Ubuntu 13.10, added one line as follows.
sudo gedit /etc/rc.local
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
chmod 777 /dev/ttyUSB0
exit 0
Takao
Sep 11, 2015, 10:19 PM
Some questions about MultiWiiConf Install on Ubuntu 13.10
#!/bin/sh -e
# rc.local
# value on error.
# bits.
exit 0
Takao
Hi, I am also using Ubuntu 13.10, can you give me some details about how to install MultiWii Conf GUI on 13.10. I have tried many times but failed. Thanks very much for your help.
Jan 07, 2019, 04:05 PM
Hi, I have the MultiWiiConf V2.4 working on Windows but I need to install it on Linux (Raspbian Stretch Lite)
I copied the application.linux64 folder and maked MultiWiiConf executable with:
sudo chmod +x MultiWiiConf
but when I run it nothing happens.
how should i do? I need Java? which version?
New Product 6DOF 10DOF 11DOF IMU All In ONE+ MCU and ALL in ONE II with GPS and sensors CSG_EU Multirotor Drone Talk 116 Jun 24, 2015 10:46 AM
Discussion MultiWii - Using radio trim in ACC mode ToddL Multirotor Drone Talk 0 Jul 28, 2011 12:16 AM
Discussion MultiWii GUI freeze troubleshooting power Multirotor Drone Talk 16 May 08, 2011 03:14 PM
Question cant get autolevel in GUI beigeboy09 Multirotor Drone Talk 5 Apr 19, 2011 03:55 AM
