Wingsail Catamaran Model - Page 16 - RC Groups
May 29, 2014, 08:10 AM
DLord's Avatar
Originally Posted by Dick L.
Doug -
I'm not sure, but sans crew to raise/lower and change foil incidence, I still think the Bradfield's wand system is the way to go for RC multihulls. Having a "self-tending system does away with the complexities of board/foil adjustments - and provides a lot less for a single skipper to worry /concentrate on. Should a class of multihulls ever evolve that would allow two (maybe three) RC control units, then some of the 'big boat" technology might be able to be employed. Until then a single skipper, steering, controlling a wing with twist, (and possible a jib) will have more than his hands full for closed course racing.
Just my opinion.
Dick
Dick, for the time being, I think you're right. There's no getting away from the fact that, at the very least, the windward foil will have to be raised every tack or gybe. And depending on the foil designer, the angle of incidence of the single main foil is likely to have to be adjusted. There's nothing like extra RM on a model as proven by the many surface piercers we see sorta foiling-and thats what the Bradfield wand system offers in abundance. See note added to my original post about UptiP foils. Thanks, Dick.
Jun 01, 2014, 04:58 PM
Dan Elliott
Its challenging! That's for sure.
Yes! If you consider being a nervous wreck fun. It's a real challenge to keep them upright, but it is a rush when the wing catches a breeze and the boat takes off like a bullet. You can't loose concentration for a second, and you really do have to practice to get good at it.
Aug 01, 2014, 09:15 AM
Dan Elliott
Foiling Catamaran Tests by Jonathan Everett
These are the latest photos of Jonathan Everett's foiling tests. Jonathan has raised the bar on his R&D efforts. Here is the e-mail Jonathan sent me discribing the tests.
I have spent a lot of time trying to get the foils working. It is not easy since I have them set up with servos and gears so that they can move fore and aft by 10 degrees. So the slot for the dagger boards has to be bigger, and it therefore will leak. I created an apron to go around it to stop the leaking, but it is not yet perfect.
I tried foiling the hulls in a river, but that turned out to be a bit of a disaster since the flow was not very smooth, with a few pressure waves and other turbulence. Also I had cut my hand so my dad was in the river with the boat on a string and I was trying to keep it straight by controlling the rudders - but that was hard with one hand and in the end the boat went side on and capsized and I lost one of the rudder foils. However, I rebuilt the foil controls with stronger servos this weekend (which took a few attempts due to various issues). The ones I have can't hold their position perfectly when subject to moderate force, so I think in the water they will be getting pushed out of position. After doing that I then took it to a lake and towed it by a boat and managed to get it to pop up on the foils, as you can see in the photos. There were a few problems with stability (the boat often came off the foils suddenly and I lost most of my control when it foiled) so any suggestions would be much apreciated! I know that I should have attached the string higher than I did but I have a feeling that I have a few more tests to go! Hopefully I will be able to implement this so I can foil it while sailing!
Cheers Jonathan Everett
Aug 01, 2014, 10:10 AM
DLord's Avatar
Foiling
Very interesting! I can't tell where he's towing from but the best way is to tow from the height of the CE because that allows the foils to experience the same pitch forces as when sailing. If you have a working rudder you can go out to one side to develop the leeway the actual boat sails with which will help a properly designed UptiP foil. This may or may not help: on my foilers the main foil or foils are set at +2.5 degrees with the rudder foil or foils at zero degrees relative to the static waterline. The foil loading is set at .188lb per sq. inch.
Pictures of my experimental test model. The ama foils are variations on the AC 34 foils pioneered by Team New Zealand. The main foil uses dual midship wands(connected to the same axle) for altitude control:
Aug 02, 2014, 11:21 AM
DLord, What is the size of your tri ? LOA, beam ??
Awsome looking boats- DLord and Johnathan
Chris Brundege
Aug 02, 2014, 12:05 PM
DLord's Avatar
Fire Arrow
Thanks! My foiler is 5.5' long, 6.7' beam, 9' rig(off the deck to top of Wing Tip flotation), 19.5" draft and 21.13 lb displacement.
Aug 08, 2014, 03:23 PM
Dan Elliott
More Details from Jonathan Everett's Foiling Cat
Here are some more photos of Jonathan's foiling design. Jonathan entered and won a science fair at his school for his efforts at building a foiling catamaran.
May 15, 2015, 12:11 PM
rc autofoiler
Hi all,
I am making an 4'*2.5'*6'+ winged foiler, it will have auto adjusting foils. any tips on hull construction
May 15, 2015, 12:26 PM
DLord's Avatar
Foiler
Sure would be great if you could post details of your design and how the foil system will work. Best of luck!
Aug 15, 2015, 12:32 PM
Dan Elliott
Hello Everyone,
Just a quick update on the Wing Sail Catamaran (Black Cat) Model. I was recently contacted by Tom Herbert-Evens, he used to be the director of the Royal Bramuda Yacht Club, but has recently taken the job as the Communtiy Sailing Manager for The America's Cup Event Authority. Tom has asked to use my Wing Sail Cat design for the America's Cup Youth Leadership Program, as a build project for school kids. It goes without saying that I was happy to help. Stay tuned you may be seeing my model at the next America's Cup.
Cheers!
Aug 15, 2015, 08:01 PM
DLord's Avatar
Ac
That sounds terrific, Dan!
Dec 05, 2015, 02:27 PM
Hi Sorry this is such a late response but just wanted to let you know that I will have a box that will pivot and the foil will be mounted in the box.
Jul 13, 2017, 05:56 AM
Hi Dan,
Do you still have any kits available ?
Paul
Jul 14, 2017, 08:54 AM
Dan Elliott
Wing Sail Model Kits
Hello Paul,
Yes I still have two kits cut-out of white PVC sheet. The kit includes all the parts made with PVC. It does not include the Carbon Fiber Beams, Mast, dagger boards or rudders. Each kit is $350.00 us. plus shipping. If you send me an e-mail to: <delliott@1220.com> I can show you what the kit includes and where to buy all the servos and hardware. I would also be happy to provide you with plans and build instructions for free if you have access to a CNC router and want to cut-out the parts yourself.
Cheers!
Discussion Simple slow plodding catamaran Gary Mortimer Racing Boats - Electric 6 Sep 30, 2011 09:50 AM
Discussion 49" long by 16" wide catamaran SirWolf2012 Racing Boats - Electric 2 Jun 29, 2011 09:55 PM
Sold Victor model Products Wildcat Catamaran kit Robert Pulse Boats (FS/W) 0 Dec 21, 2010 09:16 AM
Scale model of Seacat (hoverspeed) catamaran remondo Scale Boats 16 Apr 26, 2010 02:32 PM
RC model catamaran? john.631 Sailboats 5 Aug 16, 2005 12:46 PM
