Brand new 1.3gHz Lawmate vtx is NO GOOD
Got around to doing some tests with my new Vtx. Its been a bit of a rough start. I had some horrible audio issues starting out that I was able to more or less get rid off by adding a pot on the audio to vtx line. My problem now is, when the OSD pro voice message engages, the sound is very grainy. Anyone else have this. Its not my amp, its the audio signal generated by the OSD pro, and I can barely understand what its saying now. My 900mhz system always sounded crisp and clear. Anyone have issues like this
Update, Starting to think I may need to take a look at the osd pro board. I may also play with an attempt to shield the whole cockpit. I have some special conducive shield paint somewhere..... |
Try it (22k or potentiometr). P.S. And even more, I had to open Tx for fixing (broken wire) and saw a potentiometr inside, just touched it and move little in one and in other side. Probably it helped, too. |
Took the suspect Lawmate TX over to a friends house tonight he is a ham and rf Engineer. Put the Tx in his Faraday cage and ran some tests with a Spectrum analyzer. The results make me feel a little better. The Tx's PLL circuit is shot. Its jumping all over the place. Its a miracle I was able to even get video in the first place. I emailed Hobby wireless about it as I just got the thing from them late last week. We'll see how they handle it. Ill keep you posted. In the mean time I am going back to 900MHz.
Why did you leave 900mhz for originally?
Mark |
Lawmate 1W 1.2G audio issue
It's a sound subcarrier oscillator problem on a serie of lawmate 1.2 1W.
Try to remove the smc GREEN trim cap and replace with a bigger one. It work for me on 2 lawmate 1W 1.2........... you get a new "HiFi" sound without heterodyne noise......... Just tested with random values caps tonight, and this is the problem... Pascal |
I just add a picture
instead of removing the variable capacitor, it's better to add a simple cap in parallel
because the tuning is possible with the factory trim cap. It remains to determine the value that will give the proper range around 5.5MHz. All brand new lawmate have this problem. DPCAV sell CORRECTED transmitters for 5.5MHz sound subcarrier. Pascal |
thanks for the info ;-) Cedric |
I mean m gonna buy from them and to be sure they would send corrected Tx. Did you ask them? Thanks. |
Hi,
I talked to them (DPCAV), a lot (with my poor english), because I ordered many and many 1.2GHz 1W lawmate TX for "dev&reverse engineering"... I now know that they will add a 15 to 47pF capacitor between the *right* SMD variable cap pin and the 4MHz XTAL body (ground). Because the *left* pin of variable cap is the ground, it's the same (caps in parallel). The oscillator frequency is very approximative from one TX to another, DPCAV use spectrum annalyser to anticipate the choice of the fixed capacitor (15pF to 47pF) Error average is 33pF for all TX (6-6.5 to 5.5MHz mod). I prefer a bigger SMD variable CAP for DIY mod because tuning is easier. Pascal |
Thread Tools | |
Similar Threads | |||||
Sold | Lawmate TM-121800 1.2GHz/1000mW Video Tx | Mr.RC-CAM | FPV Equipment (FS/W) | 2 | Aug 14, 2011 12:50 PM |
Sold | LawMate 1.2GHz 1000mW Wireless AV Transmitter & Receiver | kevinlib | FPV Equipment (FS/W) | 3 | Jun 25, 2011 03:29 PM |
Help! | Lawmate 1.2Ghz 1W problems: brightness, channel selection, picture quality... | ecampos | FPV Talk | 2 | Mar 13, 2011 01:03 AM |
Alert | Lawmate 500 mw 1.2ghz and corrupted photos from Canon 5d | Mironb | RC Paragliders and Kites | 0 | Mar 08, 2011 03:56 PM |
Discussion | Difference between lawmate 1.2ghz and hobby wireless 1.2ghz | learninginverted | FPV Talk | 3 | Dec 06, 2010 08:32 PM |
