Apr 18, 2013, 02:55 PM
Alpha1actual's Avatar
Originally Posted by Horse feathers
So I'm putting together my raptor and I always like to cover leading edges and other parts with tape but I found this stuff called plasti dip. Its like a spray rubber in a can. so far I have only sprayed the canopy and it made it a lot more stronger. my freinds use this on there car they spray the rims with it and then spry the clear to give it a gloss. the nice thing is when your bored with it get a tooth pick and pick at it and you can peel it off.
Seeing your pics of the plasti-dipped canopy got me thinking. While it's not as strong or durable as epoxy, -it is quite flexible, weighs less, and won't chip or crack off. The spray version adheres well to foam, applies evenly, and weighs as much as Fusion paint. I applied two coats to the wing and motor tower (check the pic in my last post) and initial results are promising. A couple of rough rides in a small trunk and a few high speed brushes against tree branches haven't scratched or chipped it away. Also interesting is that it can be used on antenna elements with no negative impact on performance.
Apr 18, 2013, 03:14 PM
I'm glad the plastidip worked out for you. It definitely helps prevent so light damage and rash.
Apr 18, 2013, 06:56 PM
Ceros007's Avatar
Originally Posted by Maseo54
Id go with the 3 blade....more thrust. climb faster....looks better!
Originally Posted by chewytm
Might want to try that with a slightly higher kV motor, say 1350kV
chewy
I have a 1100kv motor. I will try with the 2 blade version first. The 3blades is a little expensive and I'm worried to snap one blade on landing. I have >10kit of 2blades
Apr 19, 2013, 06:29 AM
Harbor Play (3 min 50 sec)
Apr 19, 2013, 10:41 PM
I burnt up my stock motor and would like to know any recommendations for a replacement.
Apr 19, 2013, 10:43 PM
Snipe the Skies!
snipeworm's Avatar
Go with the NTM from hobby king. the 1800 kv if you want to go 3s and the 1400 if you want to go 4s
https://www.hobbyking.com/hobbyking/s...00Kv_875w.html
https://www.hobbyking.com/hobbyking/s...00Kv_550W.html
Apr 20, 2013, 03:52 AM
Hi,
The NTM 28/36 1800kv motor on 4s what prop would be needed? Does this motor need to run on 4s as I am running it on 3s with a 8*6 prop.
Apr 20, 2013, 08:26 AM
Aerial Shenanigans
woodss's Avatar
Well here's mine:
Stock motor, 40A ESC from Hobby King, 2x2200mAh 3 cells up front, stock everything else.
Only mods I've done are to completely cover the wings in Duct HD clear tape which is super strong (barely able to tear it), and made sure it surrounds the wing mounting screws too - I'm hoping this gives it a bit of strength.
Maidened it this morning but did a girly hand launch and it ended up doing a belly flop, and ripped the rudder clean off .. .the air was blue lol because that meant home time
Fixed her up as soon as I got back, and now going out to try again
Apr 20, 2013, 08:44 AM
Firatp's Avatar
Can you please give a close picture if motor installation ? 35 size is bigger for stock motor pod!
Apr 20, 2013, 09:18 AM
Yes. Both are good motors but I don't think you're going to fit either motor on the stock mount without creating a new motor mount and modifying the tower. Also, at 120 grams you will need to counterbalance the weight up front.
Apr 20, 2013, 12:21 PM
Snipe the Skies!
snipeworm's Avatar
I have have the 1800kv. I took it out but just got another to replace it I did have to cut back the opening in the tower to make room for the larger bell. And I cut the shaft off because I used the bolt on adaptor. It hauls butt too. I can launch off the grass no problem and even have good vertical flight. I will try to get some pics posted when I put the new motor back in. I am using a 8X4 APC on the 1800kv with three cell. I would use the same prop on 4 cell with the 1400 kv.
Apr 20, 2013, 12:34 PM
Aerial Shenanigans
woodss's Avatar
Maiden went well
FPV Raptor maiden (2 min 32 sec)
Apr 20, 2013, 04:59 PM
Here is the Sunrise video I took this morning with my Skywalke, long range, enjoy it & thanks for watching
Long Range FPV Skywalker DL Sunrise Monterrey April 20, 2013 (5 min 38 sec)
Apr 20, 2013, 09:10 PM
Ceros007's Avatar
is there some rule of thumb for how big the wooden blocks should be for the twin raptor mod? Like how far should it go into the wing?
Apr 23, 2013, 08:28 AM
Before We Sleep (5 min 53 sec)
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 15566 Feb 26, 2024 06:01 PM
Discussion Skywalker or Lanyu FPV Raptor? alishanmao FPV Talk 142 Feb 10, 2016 02:49 PM
Discussion New home of Trappy's "Ultimate Zephyr FPV Build" Thread timnilson Other Websites 19 Mar 21, 2011 03:58 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 05:37 PM
Raptor - how to install thread malcolmm 3D Flying 1 Jan 15, 2005 06:29 PM
