Jul 09, 2011, 04:12 PM
Cranky old fart
Balr14's Avatar
11.1v low voltage cutoff?
I've never had to set LVC on my helis, they all tell me when they are reaching the point where it'a time to quit, one way or another. With the nimh battery in my Stampede, it just gets real slow. I'm guessing that's not a good idea with an 11.1v 5000 mah lipo in my Stampede. If my calculations are correct, it should be 9.6 - 10.2 volts. So what would you set it at?
Update:
Nevermind, I think it will overheat way before that. It's quite fast though.
Jul 09, 2011, 07:05 PM
I believe your min suggested voltage for LiPo's is 3v per cell. An 11.1v LiPo is a 3s (3.7v per cell), so thats 9v min voltage. If you go too far below that, you permanently damage the LiPo battery. 3v per cell is what I've consistently seen. If the voltage drops too low, then the cell undergoes a chemical change that can not be reversed destroying the battery.
If your overheating the battery, you might have a battery with too low of a C rating. The C along with the mAh rating tells you how much current your battery can pull safely. A 5000mAh battery with a 20C can pull 100A or something. Depending on how much load is on your system, you may be exceeding the capabilities of your battery.
Jul 10, 2011, 12:19 AM
Cranky old fart
Balr14's Avatar
I always thought it was 3.2 - 3.4 volts per cell. My concern is that RC cars seem to have much different power delivery than helis. The battery doesn't even get warm. But, the motor and ESC sure do. I'm running a 30c battery.
Jul 10, 2011, 12:51 PM
3v/cell is slowly getting recognized in surface RC as too low of a lvc to make the lipos live up to their cycle potential. What you need to follow is the 80% guideline - set your lvc such that you don't use more than 80% of the lipos capacity. Mine are set at 3.4 to 3.5v/cell.
Discussion Battery low voltage cutoff Paul5910 Batteries and Chargers 5 Jun 14, 2011 12:33 AM
Discussion 11.1v low voltage? stomper24 Batteries and Chargers 16 Jul 10, 2008 08:05 PM
Low Current and LiPo Low Voltage Cutoff? cserwin Batteries and Chargers 5 May 08, 2005 11:22 AM
Jeti Low Voltage Cutoff Too Low? Eric Reitz Batteries and Chargers 9 Mar 07, 2005 01:20 PM
Low voltage cutoff w/o relay? hardlock Power Systems 0 Apr 30, 2001 12:21 AM
