May 20, 2012, 04:05 AM
FDR_'s Avatar
Originally Posted by wavezz2k
Thnx ! - Again kudos to your cool work. Considering you know the firmware incredibly well, would it be possible to 'flip' the state of the throttle stick (while hold) to a trim 5 & 6 channel and temporarily map the pots to channel? Meanwhile slow cam moves will be fine, my new 5.8 link is on a slow boat & not here yet.
No. Better to consider the DEVO 10. It has two pots (and two more channels) while it is cheaper. You only loose the color touch screen...
Sep 17, 2012, 05:06 AM
I want to buy one of devo 8s, and I am worried about two things.
First one is outdoor visibility. I read many reviews, but I have no choice.
I just want to have a radio with color LCD.
Second problem is a battery.
Some users are saying that they could flow only 4 or 5 times with new nimh battery.
I tried to find an operating time with turnigy lsd battery but i cannot.
Would you let me know how much time I operate a devo 8s with turnigy lsd battery?
Sep 17, 2012, 05:25 AM
Team WarpSquad
Batteries are not really an issue so much... just have a 2nd set or a couple of TX LiPo packs.
For visibility, you can see it, just not as easily as Devo 10 but you do have the community libraries by _FDR and others which improve visibility or you can create your own.
Sep 17, 2012, 07:09 AM
Live to learn. . .
Rafa's CB100's Avatar
I don't know to say how long my TX batteries last, but at least 20-30 packs thru the model, I'd say. I've also left mine on all morning long at the field, and it didn't seem to care. I'm using the nimh AA's from Hobby King.
As for lipos, I'd recommend staying away from them, at least for this TX. I experienced a shutdown 'loop', where the TX would not turn off without unplugging the battery. I'm not the first to experience this, and going back to a lower voltage pack did the trick.
Rafa
Sep 17, 2012, 07:12 AM
I have tried with life 2100mah and with full transmit power and backlight without diming I can run the TX for 5hours.
The 2100 is to big for TX but there is a 1700mah that will fit.
Jul 20, 2013, 07:50 PM
Helifan Ensenada's Avatar
How to setup the RX2419-D
Hello,
I have Lama 400D helicopter with Receiver RX2419, but I bought the RX2419-D to use with my Devo 8s receiver.
I have a problem because the RX2419 has different pins than the 2419-d. I cannot find a way to use it.
Can you help me out?
Thank you,
Jul 21, 2013, 10:15 AM
...if you take the time
How to adjust the sticks tention? The screw on the back only affects the throttle.
Mar 09, 2014, 02:15 PM
Happy Flying
Aux Channel on a RX802
Wonder if any can tell my the Aux 2 on the RX802 rx will not work with any switch mapping. I can a sign Aux 3 to any switch I want, but Aux 2 is will not work with any switch I try setting it to.
And also on the 6 channel RX has 1 Aux label Aux 1 I have a Devo 8s radio and this is no Aux 1 in the radio what I have not tried is just play with the two Aux to see if Aux 1 will work.
These are suppose to 6 and 8 channel rx but I can the Aux channel.
Anyone tried using the Aux 2 on the RX802 receiver and have gotten it to work?
For Sale NEW**Walkera CB100 PRO KIT (*EDIT now has pics*) EN4CER Aircraft - Electric - Helis (FS/W) 5 Aug 08, 2011 07:39 PM
Discussion Walkera new DEVO8 LP2008 Micro Helis 0 Jun 29, 2011 08:50 PM
For Sale walkera RX 2610S brand new terry74 Aircraft - General - Radio Equipment (FS/W) 0 Jun 29, 2011 04:12 PM
Discussion Practically new Walkera 5G6 FREE plus shipping cost rampa202 Coaxial Helicopters 8 Jun 27, 2011 01:59 AM
Walkera 4#3 FREE New Main Blades and New Flybar micron5 Non R/C Items (FS/W) 1 Mar 22, 2011 10:55 AM
