Jun 29, 2011, 06:43 AM
building a flat foamie
Hi i am new to building,
This is why i got this cheap flat foamy from bphobbies http://www.bphobbies.com/view.asp?id...23&pid=V086484
My question is this, how do i mount the motor on the wood that is in the kit? do i glue it? drill holes and connect with screws? both? none of the above?
Another thing is should i cut the pushrods? they are quite long
Thanks very much
Jun 29, 2011, 08:53 AM
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Use screws to attach the "X" mount on the motor to the wood motor mount. The pushrods should be adjusted to the appropriate length. (yes, if they're too long you have to cut them )
Azarr
Jun 29, 2011, 09:44 AM
Fully Sending It
Xpress..'s Avatar
Make sure the 4 screws that hold the X mount to the motor are TIGHT and have been threadlocked in place
Jun 29, 2011, 10:00 AM
I will, thanks guys
When you say threadlock, do you mean blue loctite?
And what kind of drill should i use on the wood motor mount?
Jun 29, 2011, 10:19 AM
AMA 928214
Blue thread lock is a better application for metal to metal contact. If you intend to apply metal to wood or plastic, try a little dab of Gorilla glue on the screw threads before binding them into the wood or plastic. It will secure them well and won't be so tough to replace later or require the need for heat to loosen as with thread lock.
Discussion First Flat foamie 3d plane...need help. skeasor 3D Foamies 12 Aug 11, 2011 01:42 PM
Help! 64mm shroud vibrating in a flat foamie THX-181 Foamy EDFs 5 May 06, 2011 05:46 AM
Question Strong foamie building tips? / Good foamie flying wings? aeronaut999 Slope 8 Dec 29, 2008 07:12 PM
How to mount an AXI to a Flat Foamie rcmann Foamies (Kits) 3 Oct 01, 2004 10:46 PM
New idea for flat plate foamie fuses rcmann Foamies (Kits) 0 Feb 08, 2004 01:49 PM
