Jun 24, 2011, 06:19 PM
Mmm, tugs...
patmat2350's Avatar
Build Log
Pat Builds the "Happy Hunter"
I still have a job on the ways, but here's what's next: Robbe's "Happy Hunter" tug.
There have been a couple other threads around here on the HH... and a recurring theme is "it's too expensive!"
Well yes, it's not cheap... and if you don't like it, then spend 500 hours scratch building your own, or be satisfied with the POS level of quality and engineering that comes with other "affordable" kits.
Why do I like Robbe kits? Because they are fully engineered... everything goes together as designed, and the design is fully thought out... it works. Plus, there are a number of parts which come from expensive tooling, like the injection molded mast assembly... unlike other kits which provide a bundle of dowels and just a suggestion for what the finished mast might look like, with no hint of how to secure it to the model...
I could go on.
Jun 24, 2011, 06:33 PM
Mmm, tugs...
patmat2350's Avatar
What's in the Box?
We got the HH kit from Harbor Models, along with the "optional" power and fittings kits. Also a set of ESCs for the twin motors and the Raboesch bow thruster, and a Harbor Models diesel sound module. Still working on a set of brass props and Raboesch prop shafts & tubes... the latter have to be chosen carefully to work with the Robbe kort nozzles. Also need to pick up a 10Ah 12v battery, and a suitable speaker.
The kit box itself is light, as there is a lot of vac-formed ABS in there. These structures seem flimsy, but they are tough and become quite strong when braced and assembled.
Much of the top sides is provided in cleanly die-cut ABS sheet. There are also some bundles of wire and bags of fittings... though most of the detail fittings are in the back-ordered fittings kit.
Also, two large plan sheets and a couple books with instructions. You can view the instructions online... oddly the German language web page links to one book (the build photos), and the English language page links to the text manual:
Build pictures:
http://www.robbe.de/robbedaten/pdfs/...r%20Bilder.pdf
Text manual:
http://data.robbe-online.net/robbe_p...122_1-1106.pdf
Jun 24, 2011, 06:48 PM
Mmm, tugs...
patmat2350's Avatar
What's in the Power Kit?
Two big slow running 700 motors, some basic shafts and plastic props, and odds & ends.
The Kort nozzles and rudders are part of the main kit.
We're looking at brass 60mm Kort props and upgraded shafts, they'll come in later.
Jun 24, 2011, 07:44 PM
Cheif Bottlewasher
more coffee's Avatar
Cool..
Rather spendy kit though
Jun 24, 2011, 07:45 PM
"day ain't over yet-"
der kapitan's Avatar
Well yes, it's not cheap... and if you don't like it, then spend 500 hours scratch building your own, or be satisfied with the POS level of quality and engineering that comes with other "affordable" kits. .
Well said Pat, and I agree with you on the Robbe quality---.
Jun 24, 2011, 09:11 PM
Gravman's Avatar
Pat is this one for your own use or are you building for a client?
Latest blog entry: Myrtle Corey
Jun 25, 2011, 06:47 AM
dion9146's Avatar
Cool build Pat, but aren't these kind of expensive? Sorry, couldn't help it.
Dion
Jun 25, 2011, 09:30 AM
qualls6's Avatar
I love the details in the build photos (instead of drawings). Even I could follow along with those instructions.....nah, probably not.
Jun 25, 2011, 12:58 PM
Mmm, tugs...
patmat2350's Avatar
Trimming the hull
Again, I'm not really starting on this yet... but I can prepare a few things...
First step: Trim the hull back to the indicated lines. Robbe is never clear here... from the outside, you see some wide, softly-defined molded lines, with no clear indication where the actual cut should be.
From the inside, you see sharper definition of the lines... it seems like I should cut to the tops of these... safer, I can always cut more later!
The ABS cuts easily with aviation snips, left & right handed. Make a rough cut first, within a few millimeters of the final cut, then come back for a final cut. Even the final cut can be left a little wide, so that you can finish with sanding or a file.
Jun 25, 2011, 01:04 PM
Mmm, tugs...
patmat2350's Avatar
Ballast test
With hull in hand, I ALWAYS try to go right to the float test in the Domestic Marine Test Facility. Best to know right away what the model needs to weigh, and where the weight needs to go.
Here, the bare hull weighs 30 oz. I marked the waterline in a couple spots, and loaded her up until she sat right.
The result:
5.5 lbs forward
7 lbs midships (the battery)
10.5 lbs aft
With the 2 lb hull, the model totals out at 25 lbs. With a removable battery, this will be quite manageable for one person to launch.
Of course, the weight of the rest of the model will be deducted from this weight budget... I'll do an estimate of how much that might be, allowing me to pre-locate adequate ballast compartments.
Also, good to get some idea of the weight sensitivity here... what happens if you can't avoid adding a pound? Or how much lighter should the load be, if you want her to ride higher?
I can probably remove 2 or 3 pounds aft to match the height seen in the publicity shot, where her stern is riding a bit high... good for minimizing swamping!
Jun 25, 2011, 02:15 PM
Mmm, tugs...
patmat2350's Avatar
Added up all the other kit parts (10.5 lbs), subtracted that, the batteries, & hull from 25 lbs, leaves a ballast task of about 5 lbs (float at waterline), or less for a higher ride.
Jun 25, 2011, 02:34 PM
WooHoo!
woodybob's Avatar
Dion
The Robbe Happy Hunter
Jun 26, 2011, 03:10 AM
DDG 51's Avatar
Great choice, this tug. I finished one couple of month ago, based on my fiberglass hull. Tug need a lot of power, I thing Speed 700 motors are minimum. I am planning to replace them by brushless motors.
Jun 26, 2011, 06:51 AM
Mmm, tugs...
patmat2350's Avatar
Very nice, DDG.
I'm interested in how you sealed the main deck. I see that you added an engine room cover, which allows a coaming around the main hatch... do you still have the second hatch, over the rudders?
Jun 26, 2011, 08:57 AM
let us enjoy this build.
ps: price on Harbor's site is not updated (ouch!!)...you need to add around $140 to the total amount Dave sells the kit in his website (Hunter kit, fittings set & power set).
Discussion OMG Pat's rendition of 'Happy days are here again' D B Cooper Life, The Universe, and Politics 2 Nov 04, 2010 04:47 PM
Wanted Happy Hunter,Smit Hunter ARE Red Pelican Capt.Jr2001 Boats (FS/W) 2 Oct 03, 2009 02:56 AM
Discussion Another Happy Customer -- Pat's Book P_J_Glor Scale Boats 0 Oct 12, 2008 06:13 PM
Rookie builds a Happy Fly 20 waltj2k Sport Planes 39 Feb 15, 2005 12:35 AM
Happy Birthday Mod Martin Hunter Gonzo007 Electric Plane Talk 24 Mar 02, 2004 02:30 PM
