Cool
Cylon Raider - Plans Available - Kit coming soon! - New Video
Been thinking about this for a long time.... ever since i did the Viper!
Jettmandan made a special request that I do it so i popped this together tonight. 36" Span - Same TowerPro 2408-21 Motor i always use, probably a 1300mah battery. I had to tweak the profile a bit to help the thing fly better. Mostly just enlarged the back end and shortened the front end. I am sure my buddy Rasterize will put together a cool skin for it once i finalize the design. I was thinking that it might be cool to take the outer wing section and make the whole thing pivot as ailerons! The standard will be just the section between the vertical fins as elevons. I also tossed in about 10 degrees of anhedral to really up the cool factor!! I will be posting plans soon. I might even get crazy and build one! *************UPDATE************ Here are the plans for the Raider! CG is about an inch or so forward of the front Carbon Tube. I will give some better info and a video soon! *******Recommended Hardware******** Motor and Speed Control with 9x5 prop - https://www.hobbyking.com/hobbyking/s...tor_210w_.html any 20+ amp esc. Going to need some connectors for the motor and esc - http://www.hobbycity.com/hobbycity/s...p?idProduct=68 Servos - Hextronic 9g servo (3 or 4) - http://www.hobbycity.com/hobbycity/s...?idProduct=662 Battery - 1600 Mah 3s 11.1v LiPo - http://www.hobbycity.com/hobbycity/s..._25C_Lipo_Pack Radio Hardware - Any 3 channel or higher radio will work *********Build Materials********* Carbon Tube for foam Reinforcement - 3mm OD x 2mm ID x 750mm long - http://www.hobbycity.com/hobbycity/s...idProduct=6722 roduct=6731 Razor Knife / Single Edge Safety Razor Blades Pushrod Wire - i usually use .037 but you can use any size you like Control Horns - I usually make my own from old credit cards. Hinge Tape - I use 3m Fiber tape 1/2" wide and make overlapping hinge strips. https://www.rcgroups.com/forums/showp...1&postcount=16 |
another Antihedral plane? geez...i'm having enough problems flying the 1st one you designed!!! lol!
definately cool bud..and you know..if YOU get it flying..so will I ![]() |
SGT , Very Cool !!!
Latest blog entry: Lost plans
S1 , Yeah huh ? Might be easier to balance as a tractor (spaceship guys will Howl !
build it! then i can too...
SG , looking forward to this one ... I know, i know , Still haven't built the Viper yet .... but it's on the list ...
Hey Ilectron, The guy that runs RCGroups actually worked on a design for this one but didn't end up getting very far with it.
It is tough to figure out a good way to make thinks sometimes. The trouble he ran into was there is not enough structure there to make it strong enough to stay straight! If it could be worked out it would be cool but i think the original one is cooler... and it makes more sense! GPW, i think that your "To Build" list is probably longer than mine! At least you don't have to deal with a pesky 9-5 job interrupting your important stuff. I can't wait until i get there! |
Thread Tools | |
Similar Threads | |||||
Discussion | Cylon Raider | The_Fuzz | Foamies (Scratchbuilt) | 39 | Aug 23, 2011 11:43 PM |
Discussion | Yes and Yes, it Looks Like She's Gonna Do it.... | redhotpearl | Life, The Universe, and Politics | 98 | Jun 06, 2011 11:21 PM |
Sold | Vintage Kyosho Raider complete | rc_dude99 | Cars - Trucks and Parts (FS/W) | 0 | Mar 07, 2011 03:47 PM |
Cylon Elite 18, Comments Anyone? | Buran | Power Systems | 5 | Nov 04, 2005 06:56 PM | |
My Ex-wife said YES! | avdflyer | Life, The Universe, and Politics | 8 | Jul 11, 2003 06:20 PM |
