Aug 20, 2017, 07:39 AM
The way of being is doing.
IMEIV's Avatar
Hi, if Roll and Pitch for Camera Stabilization are placed on the bottom of RVOSD 6. Where is it located the YAW AXIS ?
I soldered wires in the points indicated in the photograph but with great surprise when I connected them to the gimball the PITCH axis corresponds to YAW... How is it possible ? And at this point where is the PITCH ?
Sep 04, 2017, 02:07 AM
Have a nice day! Kristjan
kristjane's Avatar
I have problem with flashing top board on rvosd v5.1. My osd has problems with slow ahi. When I tried to flash new fw on it, main board was easy to flash, but when I try to flash top board I get error.
I bought second hand rvosd v5.1 back in 2014 and untill now it was sitting on shelf. I made few flights with it, but after watching videos on yt, I found out that my board is not working as should.
Sep 15, 2017, 03:21 AM
raulvolador's Avatar
RVOSD autopilot landing in FBW
Hi,
I used to turn RVOSD autopilot OFF in all of my landings. After some crashes I start letting autopilot switched ON for landing.
In this video you will see first a bad landing due Autopilot turned OFF followed for another right landing with Autopilot ON.
EasyStar II RVOSD autopilot landing in FBW (0 min 40 sec)
Notice how autopilot helps you fighting against strong winds into glidepath.
Flight mode used is FBW (Fly By Wire), remember to start the shot with enough speed, it is advisable to start the maneuver with a steep descent.
Cheers.
Raul
Sep 15, 2017, 04:09 AM
IMEIV's Avatar
Originally Posted by raulvolador View Post
Hi,
Cheers.
Raul
I agree
Sep 16, 2017, 11:50 AM
You can't take the sky from me
Rastislavko's Avatar
I'm using FBW for hand launch as well ;-)
Sep 16, 2017, 03:44 PM
fly by night
BCSaltchucker's Avatar
quick Q about RVOSD. What is the stick/aux input to enter the menu system without the RV remote?
also, with RVOSD 5, do I just plug my RSSI line into the temp-sensor pin?
Sep 16, 2017, 04:02 PM
1) Channel connected to "auxilary input" will bring you in-flight menu. But it's not the same menu system as with IR remote. Full configuration is available only via IR remote.
2) Yes.
Sep 16, 2017, 04:06 PM
fly by night
great thanks. forgot these things, been a few years since i used my rvosd
Sep 16, 2017, 06:03 PM
IMEIV's Avatar
I have finished my MINITALON and installed RVOSD 6. I have done all my setup without any problem.
While I was doing my maiden unfortunately I have a problem. I could set my cruise throttle but not my glide throttle.
My glide throttle is set at 1.10ms and I can not change it how I did in the past. I use Ruddervator mode and Throttle Control FIXED.
Instead I use another RVOSD 6 but in a Ranger FPV plane in Regular Airplane Mode and I can set cruise throttle and glide throttle.
Why can not I set Glide Throttle in Ruddervator mode ?
My both osd version is :
Video:
6.02
Sensor:
6.06
Sep 25, 2017, 08:57 AM
Zephry ZII user
Rybskee's Avatar
Did somebody connect Rangelink and RVOSD with WORKING RSSI output?
Sep 25, 2017, 09:00 AM
400' + is where fun starts.
Martin Y's Avatar
Yes. Dont direct connect use a 10K resistor so not to load the Rangelink rx.
Dec 11, 2017, 03:50 PM
Mateus Dante
Hi!
Someone have a RvOsd for sale?
I'm interested.
Thank you
Dec 29, 2017, 08:17 PM
KC9TPL- Get Legit
BloomingtonFPV's Avatar
I have a RVOSD v5.0 and I want to add in the second aux channel. I noticed on the RangeVideo site that Alex hasn't been active for 4 weeks. I'm worried that I won't be able to get an unlock code from him if I upgrade. Anyone know if it will be possible to upgrade to Main_5.07 and Graph5.05b?
Dec 30, 2017, 02:07 AM
IMEIV's Avatar
Hi, I think if you write to Alex for unlock code he will answer to you in a couple of days.
Jan 20, 2018, 04:23 PM
KC9TPL- Get Legit
So no reply in 2.5 weeks and now the forum is down. Anyone know how to reach Alex?
Discussion Maiden Reports 12345 Arizona Model Aviators 744 Oct 16, 2015 09:17 PM
Help! RVOSD thermal sensors rcmonster99 FPV Talk 16 Jun 20, 2011 10:21 AM
Discussion Weekend weather reports neck Arizona Model Aviators 13 Jun 10, 2011 04:59 PM
Discussion where are the Joe Nall horror "reports? guy hanson Radios 49 May 18, 2011 12:06 PM
Discussion Finally Fixed the Country Reports daboz Dynamic Soaring 5 May 16, 2011 02:51 AM
