Nov 03, 2011, 01:19 AM
DS will change your life
SpeedsterDEN's Avatar
Originally Posted by aeroknot
Thanks - I'll cut the wing template and elevons as one piece as you did with your blue foam, except I have pink 2" thick foam here. I'm using your 29 cm wing templates and just extending them the aileron width longer, but keeping the wing template the same thickness.
Good job teaching the children building airplanes!
For the katapult launch, did you use a tow hook, or your velcro attachment?
Its a hook, Its just a straight piece of 2,5 mm pianowire pressed in the front of the fuselage in front of the battery in a angle of 45 degree, and reinforced with fiberglass tape.
Nov 03, 2011, 06:20 AM
Build ALL the models O_O!
WLJayne's Avatar
Wow it's good to see so many of these being built! They all look great!
Nov 03, 2011, 07:49 AM
still learning
aeroknot's Avatar
Thank you. Hopefully will start making the templates today.
Nov 12, 2011, 12:50 AM
remotely sensitive
woodenshoe's Avatar
My Alula is getting dusty!
Not flying the Alula much at all anymore.. not since I put together this tough glider.... I don't how many times I have slammed it into the pavement. I definately have gotten worse at landings because it does't matter..
Nov 17, 2011, 09:29 PM
still learning
aeroknot's Avatar
My first ever hot wire cut wings. The next ones will be better, but I'm building the light wisel with the ones I have - and the next build will be better for the experience. I know where and how I need to improve the hot wire cutting...
Not a lot of free time for building right now - I like a leisurely build time frame. Looking forward to completing the build though in a few weeks.
Nov 23, 2011, 11:57 AM
Hi Aero
4 cm at the root and 3 cm at the tip, both types.
We Have cut wings for 8 Wisel in the evening school for children this evening
Video from the Evening school last year, where we were building Cobra planes.
This year we are making Cleancut (Depron, indoor combat planes), and Cobra and Wisel.
http://www.youtube.com/watch?v=gqHbCbj4IQM
Cheers
S
The wing cut for the children
Its very fast when the cut are propperly prepared.
Airfoils for the wing is made in aluminium, and pollish so that the wire dont get stock. Wood will also do it.
And some wood pieces is made, to lay under the airfoils when fixed at the end of the foam, just to get the right washout and secure that the left and right wing are like each other.
The overall wing shape is made in a piece of cardboard,
Cheers
S
Nov 29, 2011, 04:22 PM
still learning
aeroknot's Avatar
Thanks for the details speedster
nice cores!
just glued the battery boxes in - servos, control rods and receiver, then ready to fly.
Nov 29, 2011, 07:27 PM
still learning
aeroknot's Avatar
Almost done.
I promise to do a better build next time
I did the washout as you recommended post 34
weight at 190 grams but still need control rods and some ballast to balance at cg (will start cg at 94mm)
Nov 30, 2011, 01:19 AM
Almost done.
Cool, it will fly like a dream
Nov 30, 2011, 03:53 PM
still learning
aeroknot's Avatar
added a tow hook beneath the battery boxes.
the aft back pointing tow hook length is 31mm.
Should I cut it back to 10mm?
After that, does it look OK?
(hook won't be used anytime soon)
probably will fly the light wisel tomorrow, although may not have any wind.
At least will be able to glide some.
thanks - aeroknot
Nov 30, 2011, 04:00 PM
thanks - aeroknot
10 mm is ok, then you can katapult it with a bungee.
for normal towing we just use velcro tape, just 1 cm long.
Good luck
S
Dec 01, 2011, 07:36 PM
still learning
aeroknot's Avatar
glide test was good - no trim necessary and CG was good
atlatl launch since no wind and no bungee was available.
Two guides on the bottom for the atlatl launcher - need to buy some bungee cord.
Nice glider. My first motorless rc plane flight!
Dec 02, 2011, 07:34 PM
charango
A quick question is the Cg measured from the wings nose tip or from the trailing edge?
Dec 02, 2011, 07:55 PM
remotely sensitive
woodenshoe's Avatar
I found it is 9.5cm from the leading edge where the wing meets the fuselage. I have flown + or - 5mm from that spot. heavy winds with ballast i move CG closer to the leading edge about 5mm. I am sure cg varies do to the homebuilt nature of this glider and weather you have a fuselage or not. SHoe
Dec 03, 2011, 04:30 AM
Yes to all, just my words
Discussion Just bought a used swift. Need you input renerc Electric Heli Talk 31 Mar 21, 2008 10:28 AM
Sold Bandit--New with just about all you need. Reduced utcadman Aircraft - Sailplanes (FS/W) 13 Oct 26, 2007 09:36 PM
Discussion Just approve the program AG, you don't need to know the details. thunder1 Life, The Universe, and Politics 13 Aug 19, 2007 02:25 AM
