ESM BF 110 Zerstorer! - RC Groups
Jun 08, 2011, 11:49 PM
80's Metal....
HKing_PwnsMe's Avatar
Well this is odd.. for some reason I thought there was a conversion of this awesome plane on RCG.. but I couldn't find it!
So.. if anyone's interested.. here's my Electrified ESM BF-110. I just love this plane. It's my umpteenth conversion but my second twin.
I'll post details later but i'm about to hit the sack.
Some quick notes.. I'm running the following...
2 x 50-65 Turnigy SK Motors
8s 8000mah 30-40c Batteries (2x 6s 4000mah batts and 2x 2s 4000mah batts)
2 x Common Sense RC HV 80 Amp ESCs
2 x A123 1100mah Rx batts
R921 Receiver.
WOT = about 3600 watts which settles down to about 3000watts WOT.
Jun 09, 2011, 08:39 AM
In NY's beautifull hills
staggerwing's Avatar
Nice ! I was curious about specs so here is a link for others--
http://www.troybuiltmodels.com/items/ESMBF110C-95.html
Jun 09, 2011, 09:21 AM
That's beautiful!!
Jun 09, 2011, 10:46 AM
Head NEAT geek
Tom Hunt's Avatar
https://www.rcgroups.com/forums/showthread.php?t=996469
It was in warbirds.
Mine was a product review in FLY-Rc a few years back.
Tom
Jun 09, 2011, 12:23 PM
80's Metal....
Thanks guys..
I'm hoping to get maiden pics and video this weekend. After a few successful flights I'll start on a different paint job as well as the detailing. I also have the Ty Brown cockpit kit for it, it's quite detailed. Gear doors will be the last item to do.
Forgot to mention it sits on Sierra retracts.
It's heavy though, around 23-24lbs.. but it should fly well.
80's Metal....
It was in warbirds.
Tom
Thanks Tom.. I thought I remembered reading a build log for it. I also read that Fly-rc review awhile back, is it still online?
Jun 11, 2011, 11:50 PM
80's Metal....
Here are some maiden pics... taken by my flying buddy.. she flew great!
Jun 12, 2011, 11:56 AM
TripleW's Avatar
Congrats!
That a sweet ride. TW
Jun 12, 2011, 12:01 PM
TripleW's Avatar
So you have two receiver batteries for cg purposes? Did you have too add any weight? TW
Jun 12, 2011, 12:09 PM
80's Metal....
Thanks!
On planes this size, I usually use two receiver batteries (say 2 x 1100mah A123s vs 1 x 2200mah A123) just for redundancy. I've seen too many planes go down because of a bad switch or wire coming loose/solder joints going bad etc. Since the R921 Rx has two power inputs I decided to take advantage of it.
It did help with CG as well... even though I have everything as far forward as possible it was still a bit tail heavy! I couldn't believe it.. I thought the motors, batteries/battery boxes would be more than enough. We ended up having to add weight (with rocks at the field.. lol). I really don't like adding weight like that so I'm going to fly her on 2 x 8s 5000mah setups.
Jun 12, 2011, 12:48 PM
TripleW's Avatar
Is there room for reciever batteries in the nose? TW
Jun 17, 2011, 02:32 AM
kittykatjaz's Avatar
Absolutely awesome plane. Looks great in the air
What do use to fasten the cowling's under the batteries?
I am doing an electric build with an ESM Spitfire and have cut the cowling like you but am using screws to fasten it on which does not seem like the quickest most elegant way for easy battery swaps.
Jun 17, 2011, 10:03 AM
80's Metal....
Thank you!
I actually used an allen head screw so I could just use my fingers (with blind nuts glued into the nacelles). But even that has become annoying so I decided to install a twist lock deal I bought from home depot. They type that fits through horizontally then you twist it vertically to lock it down. I'll get pics as soon as the install is done, I like it because it's very small and the exhaust stack pretty much hides the whole thing. After some paint it should be almost invisible.
I'll be postiing video of the maiden today.
Jun 17, 2011, 10:23 AM
80's Metal....
Here is the maiden on video.
I really should have waited since it was rather windy (sorry about the audio!), but it was too tempting.
I goof up the landing a bit, it's about 25-26lbs.. but flys light. Plenty of power, it cruised at about 1/4 to a little under 1/2 throttle. The plane was tail heavy on this flight, with full down trim it still flew nose high and the elevator was touchy, but manageable. Hardly any aileron/rudder trim.
I'd say about 1/8th throttle on landing, it may look slow coming in because of the angle but as it flys by during touchdown you get a sense of it's landing speed.
Chong's BF 110 (5 min 33 sec)
Jun 20, 2011, 04:44 PM
kahloq's Avatar
Nice job. Ill get mine flown pretty soon maybe. LOL. Too many projects.
Build Log Bf-110 Zerstorer: This One Under Entirely New Management John Rood Slope 61 May 30, 2015 08:49 AM
Sold Flair Bf-110 pmisuinas Aircraft - Electric - Airplanes (FS/W) 3 Mar 25, 2011 05:33 PM
Sold Parkzone BF-109 w/E-Flite Power 25 $125, $110 shipped (electronics only) jpt1205 Aircraft - Electric - Airplanes (FS/W) 2 Mar 18, 2011 06:33 AM
BF-110 Progress Slope Nut Scale Kit/Scratch Built 6 Nov 15, 2001 01:50 PM
Motors for ME BF-110 Aero-BearAZ Power Systems 6 Jun 28, 2001 12:59 AM
