Aug 22, 2016, 02:11 PM
nom
nom
nom's Avatar
I flip my control surfaces so that it is on top rather than underneath.
Aug 22, 2016, 03:47 PM
What Goes Up...Must Come Down
abjets's Avatar
Originally Posted by Flying Pig
It's been on and off for a while now, but finally got my F86 kit operational. Placed the rec and extra wires in the canopy. Upgraded the esc as well. Balances perfect (at least per instructions) with 3 cell.
Have there been any ideas for protecting the ail control horns? I looked through thread but didn't see anything specific. Don't want to mount the drop tanks.
Here is how a lot of us do it... Run your AIL horns up through the wing...
Feb 17, 2017, 05:02 PM
leo.geo's Avatar
Can anyone help??? Looking for the edf blades replacement.. 3 blade ideally !!?? Anyone got one or know where I can get some ?? Cheers
Feb 17, 2017, 09:42 PM
abjets's Avatar
They are hard to come by these days. We need someone to 3D print some!
Feb 17, 2017, 10:50 PM
Old !Bold Pilot
kevinkal's Avatar
I found some 35mm edf parts at hobbyking about 1 year ago.. they were the stock Skyangel units with the fan shroud and both 3 blade and 5 blade fans. They were from the international warehouse. It might be worth checking to see if they still have some units in stock.
Feb 18, 2017, 11:41 PM
that's gonna leave a scar
KCinNC's Avatar
man, I didn't know the 35mm had the 3 blade setup !! Huh
Feb 19, 2017, 09:28 PM
abjets's Avatar
Key for running on 3S with the 9000kv motor
Mar 26, 2017, 11:38 PM
osern's Avatar
Hi,guys,
What`s the max 3s setup AUW with single EDF you guys are flying?
Most of the AUW are around 116g , but AUW of my scratch build F-16 comes at 168g before paintting,
It`s floaty with 474mm win span(almost the size of 50MM EDF F18) that can hand launch with 70~75% % throttle ,will torque roll over 75% throttle with hand launch.
The W/T ratio before painting is about 1, the thrust is about 158g maybe more(is this normal?).
What I don't get it now is how it does fly with this loading?
The loading is reaching the edge of max 180g of 35MM thrust,now I`m worry about the 10g extra paint weight,
Any case with this loading that flies?
Thanks for helping.
flight test video:
70~75% throttle, cut throttle before hitting ceilling
https://youtu.be/huAKzVBe5Cc?t=1m2s
Mar 27, 2017, 11:02 AM
abjets's Avatar
Lighter is better...especially with these little gems. I would say that if you were really worried, maybe remove your wingtip missiles (lots of drag), and instead of painting, just use colored markers (Sharpie's depending on foam)??
My 35mm T-45: 3s 460 mAh 25-40C AUW=134.2g
My 35mm F-86: 86.0g empty 3s 460 mAh 25-40C AUW=131.3g
Hope this helps!
Mar 27, 2017, 06:44 PM
osern's Avatar
Thanks,abjets, they were close to my origin one, seems like that 130g is average in this win span on 3s.
Did your jets encounter any torque roll with hand launch on 3s?
I built this large version to expand win span to solve strong torque roll and low speed dropping on 3s, the problems were overpowered and light weight,now become tug of war for W/T.
I love AF scheme paint,now it leaves no choice but stripe scheme .
cheers
Mar 27, 2017, 07:23 PM
abjets's Avatar
Originally Posted by osern
Thanks,abjets,
Do your jets encounter any torque roll with hand launch?
I built this large version to expand win size to solve torque roll and low speed floating isue.
Torque roll or too much coffee... They are small twitchy birds...but the 3 blade fan on 3S isn't too bad.
Mar 27, 2017, 08:30 PM
osern's Avatar
Indeed too much coffee got me hand twichy!
I guess the fresh battery boomed out too much power or my little bird got flue that rolled and flip.
Just give it a shot, maybe this big bird does fly!
Mar 27, 2017, 09:42 PM
abjets's Avatar
A strong, level launch into the wind...let it get up to speed before too much AIL or ELE input... godspeed!
Apr 06, 2017, 06:17 AM
osern's Avatar
Final Flight
Hi,guys,
Thanks for helping.
flight test video:
https://youtu.be/7qapopb3akU?t=1m24s
Result of small 35MM EDF on 50MM EDF win span jet flight.
Windy day flight equals to Final flight~
35MM EDF on 3S ran out of juice quickly even if fly with 90% throttle, extra filler weight made me unable to do any paint job for 180g AUW, the cheater holes helps squeeze out more power, how ever I broke the last back up 3 blades prop, now she is for 50MM EDF now....
Apr 06, 2017, 09:33 AM
abjets's Avatar
Looks like your CG was too far aft?
New Product JPower/Banana Hobby 40mm Foam Mig-15 and F-86 ducted fan Mikey 68 Micro EDF Jets and Power Systems 558 Aug 12, 2020 01:13 PM
Discussion Mini Mig-15 EDF from Hobby King Dreamcatcher Foamy EDFs 6 Jan 16, 2012 10:58 AM
Build Log Hobby King Micro A-6 & F-86 Jets tallflyer Foamy EDFs 4 Jun 04, 2011 02:05 PM
New Product J-Power 30mm EDF Jets (F-86 & Mig-15) xplaneguy Foamy EDFs 1 Jan 16, 2011 06:59 AM
Park/indoor EDF F-86 and MiG-15 production news! Thomas B Parkflyers 8 Feb 06, 2002 07:30 PM
