May 22, 2011, 11:58 PM
30 000 rpm, the magic number.
I know now that one should aim to get a motor that spins at 30 000 rpm's for optimal power and speed. But that is unloaded right? What is the optimal loaded rpms? I want to look more into this as some motors will loose more rpms in the water than others. When you take a 2835 and a 2860 both at 2200kv, surely the 2860 will have a higher rpm in the water? Does this mean when getting a smaller motor like a 2835 that you should rather look at a 2500kv motor to get the same speed as the 2860?
Please share
May 23, 2011, 12:03 AM
I feel the need for speed!
scorpion1's Avatar
The 2835 2500kv wont be able to spin as large a prop therefore speed drops anyways. A motor can only put out so many watts(power) so a smaller one with higher kv still cant compete with a larger/lower kv motor in top speed. The larger motor can turn more prop. If you have a 4 cylinder car and give it a 6th or a 7th gear, it doesnt have enough power to rev out all the way and will "bog" down................
May 23, 2011, 12:42 AM
So what exactly is the optimum RPM for loaded regardless of prop size? I assume there would be a point where the cavitation would cause barely any increase in forward momentum. I have noticed lots of the mind blowing speed boats are actually in the 40-50k range unloaded.
May 23, 2011, 01:38 AM
Cookie
10x8's Avatar
Please share
Look at this chart I have posted 4,987,543 times. Like you say, around 30k is good for sport setups and the higher red + some, for saw setups.
I have always said, lower kv motors with more volts and bigger prop is best. Try this method and just 'gear' up or in our case, prop up. Get the best, highest 'C' rated battery you can afford and try to get an onboard datalogger to measure your amps. Of course, check your temps with a proper guage of somekind and don't say, cool to touch or warm or my finger didn't burn. Do it right and you will be rewarded with a great running setup.
Biggest kv I have in a f/e is around 1600kv. I just give it more volts and pick prop accordingly. Torque is your friend in f/e and always remember that.
Pete
May 23, 2011, 01:51 AM
Cookie
10x8's Avatar
And, you'll typically drop 2-4k from unloaded.
May 23, 2011, 02:11 AM
Pete
Lol.
Thanks for the chart, again
May 23, 2011, 02:37 AM
Cookie
10x8's Avatar
Lol.
Your most very welcome.
Volts are your friend too, even with the almighty spark.
Just remember, the point of brushless setups is to be efficient.
Pete
May 23, 2011, 03:08 AM
Pete
WOW my boat will be doing great then on 4s 2000kv 2074 29,600 rpm I great now i cant wait to run it.
Michael.
Just hit the Sweet spot.
May 23, 2011, 03:24 AM
Michael.
2074? It would barely move Just joking, I know you meant to say 4074.
May 23, 2011, 03:48 AM
opps my mistake.
May 23, 2011, 08:32 PM
wparsons's Avatar
There is no magic "perfect" rpm to aim for. As long as you prop according to motor size, kv and batteries you'll be fine.
May 24, 2011, 05:12 AM
Oi you got another chart for prop size to motor size?
May 24, 2011, 05:23 AM
I would also like to have such a list
For Sale Xmods H2 Many Upgrades Custom Body Lift Offroad Kit Awd 30,000 Rpm Motor edge5foamy Cars - Cars and Parts (FS/W) 3 Apr 13, 2007 11:45 AM
For Sale Super Slicks Motors 19,000 rpm and 22,000 rpm LOGICAL_PSYCHO Aircraft - Electric - Power Systems (FS/W) 4 Feb 09, 2007 02:34 PM
Discussion Measuring 30,000+++ RPM GregG High Performance 24 Oct 06, 2006 03:00 PM
30,000 RPM? Steven D High Performance 3 Jun 24, 2001 10:06 PM
