May 22, 2011, 06:43 AM
richos's Avatar
New Product
DelTang DSM2 Micro Receivers
DT Rx33 DSM2 Micro Receiver with 2A ESC (JST-SH)
Rx35 DSM2 Micro Receiver with 2A ESC (JST-ZH)
Rx71 DSM2 Micro Receiver with 2A ESC
Rx41 DSM2 Micro Actuator Receiver with 2A ESC
Rx42 DSM2 Micro Actuator Receiver with 2A ESC
Rx43 DSM2 Micro Actuator Receiver with 2A ESC
Some are Actuator Receivers Cool...
http://www.micronradiocontrol.co.uk/rx_deltang.html
May 22, 2011, 06:46 AM
richos's Avatar
DelTang Web site here
http://www.deltang.co.uk/index.htm
May 22, 2011, 10:00 AM
Gravity is a harsh mistress.
Tim Wolff's Avatar
Has anyone tested the actuator receivers with a Spektrum DX8 transmitter?
May 22, 2011, 12:58 PM
Hi. The rx's are mine and I have a Dx8 which works fine with them. DSM2 mode of course.
Rx34 is worth mentioning as it has the Molex Picoblade connector which is what the small HK servos use.
Regards, David.
May 22, 2011, 07:47 PM
Originally Posted by David T
Hi. The rx's are mine and I have a Dx8 which works fine with them. DSM2 mode of course.........Regards, David.
I have two of David's Rx's (an Rx40 and a Rx24, now replaced by the Rx31).
Both are completely compatible with my DX6i
May 23, 2011, 01:25 AM
Team30 Micro EDF
NitroCharged's Avatar
Nice stuff David!
May 23, 2011, 03:10 AM
starscream4002's Avatar
really interesting...
just one question, does DSM2 work with a DSMX DX6i?(yup you guessed it, my DX7 is dead...accidentally dropped it off a ridge... taking sth else out of my "flight bag")
SS
May 23, 2011, 03:17 AM
Yes. DSMX transmitters can do DSMX and DSM2. They will use DSM2 with receivers that can only do DSM2.
Thanks, Nitro.
dt.
Jun 27, 2011, 02:21 PM
Ego varius quis.
Cheesehead's Avatar
The Deltang RX43 looks very impressive. 0.35 grams for three actuator outputs and an ESC - and for about 25% less than the price of a Plantraco 2-channel RX of the same weight. All we need now is some actuators.
Jun 27, 2011, 02:43 PM
Plantraco have them as does Didel. Also some on Bidproduct but never seen those in the flesh.
I sold my winder as no one was buying coils anymore. Several years ago I made remote actuators from etched brass parts. Very labour intensive.
When the Kyosho and Spektrum bricks came out the interest in actuator models seemed to drop significantly. Not often you see people post actuator models anymore. I plan to build some when my workshop is set up again. Because I make the coils myself they are ultra cheap and therefore I don't mind splashing out on a nice RX like the DelTang. A 7mm pager and a 50mAh cell and you are in business....
Jun 27, 2011, 03:14 PM
Tim Wolff's Avatar
And very nice!
I still have mine and recently purchased one of these receivers to use with them.
Jun 27, 2011, 03:26 PM
I don't know how many I sold in total - probably 60-80 pcs. Unfortunately some of those assembled with CA had the coil come off the frame in crashes. Laters ones assembled with epoxy should be OK. Maybe add a tiny blob of epoxy for safety?
I did some work on remote actuators made from laser cut parts but abandoned the project. With $4 micro servos nobody wants to pay $15-20 for an actuator.
Jun 27, 2011, 03:29 PM
Tim Wolff's Avatar
Mine were kits. Assembled the coils to the frames with epoxy and mounted only with water soluble adhesive.
I'll be doing a Peanut or Pistachio when I have the time to get back to a micro.
Jun 27, 2011, 05:43 PM
Wabi-Sabi
coriolan's Avatar
Flying-kit too has small actuators:
http://www.flying-kit.com/index_epro...roducts_id=561
And also a servo output to actuator driver:
http://www.flying-kit.com/index_epro...roducts_id=559
Jun 27, 2011, 05:57 PM
Those look OK although I find it hard to trust the weight they state.
Sold Pair of new OrangeRX Spektrum DSM2 compatible receivers jabull Aircraft - General - Radio Equipment (FS/W) 0 Apr 02, 2011 12:19 AM
Sold $15 each - Spektrum AR6100/AR6100e DSM2 6-Channel Receivers RC Plane Heli JimG_AZ Aircraft - General - Radio Equipment (FS/W) 18 Mar 23, 2011 02:13 PM
Sold $15 each 7 - Spektrum AR6100 DSM2 6-Channel Receivers RC Plane Heli JimG_AZ Aircraft - General - Radio Equipment (FS/W) 7 Mar 21, 2011 10:30 AM
Sold Two Berg Receivers with micro antennas for sale 20 bucks newguy Aircraft - General - Radio Equipment (FS/W) 2 Mar 20, 2011 10:27 PM
Discussion Hobbyking 2.4 ghz DSM2 micro receivers karfrik Scratchbuilt Indoor and Micro Models 5 Feb 04, 2011 01:08 AM
