This thread is privately moderated by coriolan, who may elect to delete unwanted replies.
May 18, 2011, 12:41 PM
coriolan's Avatar
First build for FD 1 gram Rx
The first bird for my Flydream 1 gram Rx, inspired by these Frog FF models:
http://www.houseoffrog.co.uk/
At 14" span its kind of between the junior and senior serie, the wing is 3mm depron with sanded airfoil and the fuse mostly 1/16" balsa with lightening holes and covered with red solite. The top fuse in the front is sanded 9mm depron. So far it weight 24.5 gram with motor(AD-C5 /3700Kv)so I am still wondering about using Toki servos,AS-2000 or the Flydream which weight almost 3 grams. It will be RET and one cell (180<240 mA)and the prop is GWS EP-4530 which give good performances with that motor, the esc is the excellent TGY DP 3A. Since I have several of these Rx I have other builds in the pipeline
Found Foam Kit for first build Viper82 Aircraft - Electric - Airplanes (FS/W) 0 Mar 25, 2011 09:29 AM
Sold 4.5 gram dsm2 6ch rx nip 12 shipped usa ---- tower pro servos 5 for 20 ZEROSKIN76 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 8 Mar 24, 2011 08:48 PM
Yippee! Took 1 of my first 12 mm powered GWS planes out for a checkout flight. cyclops2 Electric Plane Talk 17 Mar 23, 2011 01:49 PM
Discussion SUB- 1 Gram 2,4 ghz DSM2 compatible Rx (spektrum compatible) bmaaa Scratchbuilt Indoor and Micro Models 11 Nov 04, 2009 03:02 AM
Too Much Wind?? not for the X-FD-1 AirWarriorBelgy Parkflyers 1 Nov 11, 2002 07:51 AM
