I broke the USB adapter off my Quadrino in a recent crash and am using an FTDI to USB adapter to connect through the serial pins. I am able to read/write in MW config, but cannot load a sketch. I asked this in the MW thread here:
https://www.rcgroups.com/forums/show...ostcount=27927 The guys in there say I need another connection to a reset, but the serial bus on the quadrino doesn't have a reset pin. Is there a reset pin on it somewhere that I'm missing? |
Ya I guess I could do that, the connections just looked kinda small and I didn't trust my soldering, but if there's no other option I will.
Take a snap shot of the area and send to the Guru and witespy, see what they say?
Hi guys,
Maybe a noob question, but should PID values be different for 3S and 4S batteries? I am flying both now to understand what I need and on 4S my quad is a bit more wobbly. And second question, how do I use the barometer? I tried to enable it yesterday several times and every time my quad either ran up high as hell, or dropped onto the ground just after enabling it. |
2. which baro you got... the precision of baro will cause the problem also, do you have a "wind shield" on fc.. the baro will be affected by the airflow.. if you increase throttle, the air pressure around baro will increase if not shielded.. vice versa. so you may want to put a shield on it |
2. I am using quadrino rev 1e with 'MS5611 High Resolution Barometer' and yes, i have a shield. I mean, maybe I am not doing something right. Like the position of sticks when i enable baro. Or maybe I should compensate this fall/rise after enabling baro by throttle stick? |
Reason: Add
if possible you might want to check the baro reading when it is hovering.... or when prop is on... safe way is 1. bluetooth (several buck can save a lot of time.. esp for tuning) 2. fix quad on a not moving object... and let the props run |
I think I might have a problem with hovering on one altitude before enabling alt-hold. I recall that it may have been moving up or down a bit when enabled alt-hold. Btw, another question - i have a shield only on top of the board, but there are holes under the board and on the sides, because the base plate of the frame is smaller than my shield. Will it matter? |
2. I guess it is good enough.. |
If Colin would provide a Quadrino with integrated bluetooth, i'd buy it straight! getting experience FPV'ing the Quadrino (only gyros in this flight and it is raw footage from Gopro1 set to R3) http://www.youtube.com/watch?v=SYqEc5iRtU4 |
According to the datasheet there is a RESET pin on the ICSP port
Thread Tools | |
Similar Threads | |||||
Review | Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review | tailskid2 | Scale Fuel Planes | 20 | Mar 09, 2018 08:44 PM |
Help! | need new flight controller recommendations | n3m1s1s | Multirotor Drone Talk | 115 | Jan 09, 2012 10:38 AM |
Subsonic's Motrolfly Plug and Play Power System: Motor, Controller & Battery Review | Michael Heer | Electric Power Systems | 27 | Dec 16, 2010 01:36 PM | |
Data | Plug 'n Play separates: An Esky CP2 with an E-flight 2 in 1... | elan | Micro Helis | 3 | Mar 19, 2010 08:51 AM |
Discussion | Air Hogs Plug n'Play Flight Deck Simulator | trust416 | Micro Ready-to-Fly | 14 | Aug 05, 2007 10:44 AM |
