Bajora,
Not sure whether BV was previously aware of the electrolyte project but yesterday he sat down next to it, and gave a good inspection. The micros are not usually on his radar so for a few min we chatted about the small side of edfs. I brought the custom shrouds and rotors which he got a kick out of. Jack, Yeah no doubt, I saw CNC equipment and other tools that you'd never expect to see at a model manufacturer. They use some very advance machinery to maintain tight tolerances. I was drooling over the molds.... BV is in great shape! Apparently if he's not flying he's at the gym....those are some good priorities! |
Latest blog entry: original Y/A F-18 Kit
Just fishing here but I seem to have bad luck with my servos! I have 5 brand new DS378HV in my Electra, flaps, ailerons, rudder. One of the flap servo's is always buzzing, yeah it is the typical digital servo buzz, but it never stops no matter the servo position or load, i.e. disconnected from the flap. That's a little odd. But when I put everything together Monday another servo, the rudder servo, was not centering, and not moving smoothly either. But after "exercising" it a bit with the stick it returned to normal operation. Not good. So Horizon support says send them back and I guess I will but have you guys had trouble with these servos? Radio is JR11X, Spectrum 12000 Rx, 2x 2s LiFe packs (6.6v) Thanks.
Jack |
Thanks Jack! Sure appreciate your thoughts, could always be something else.... FWIW I used to compete in F3A pattern back in the 80's and since then i've always thought JR servos were top of the line. Some of the Futaba guys wished they could run JR servos back then. long before digital's though.
Jack |
OK got the new rudder servo in (thanks Heather!) and she is ready to fly. I decided I could live with the noisy flap servo. Did taxi it around in the street tonight. Followed the manual setup except moved the CG forward 1/4" and reduced the elevator throw a bit, high rates are 7/8" instead of 1" (thanks Jack D!). I'm gonna run 25-30% expo initially. Does anyone have a wag for flap to elevator mixing? My Habu 32 needed down elevator with flaps and this was spec'd in the manual, that was nice for the first flight.
Hey husafreak
I thought I needed a mix on mine too but you don't. I was getting a ballooning effect but it was because i was moving too fast. Just slow it down when you drop flaps and it will be fine. I decreased landing flaps a little per the manual and on non windy days I can do power off landings. Glides right in. |
Jack |
Wow, the Electra must be designed very well if only 4 clicks down trim are needed with the flaps full down. That can easily be handled without sweat on that critical first flight. I imagine the CG of Jacks Electra and LTR450 is slightly different. I do use the flap system and also flight modes. FWIW I fly EDF's (fast) 3D (slow) Hotliners (both!) and helis (?) and the way we use flight modes and switches has made a great impact on the ease of flying them, just gotta remember which is which! As for flap to elevator compensation that can vary wildly, from 0 to 0.5mm in the Electra to 2mm on the Habu to 7mm on my Typhoon hotliner, and it was pretty hard to land that dang Typhoon before I got the mix ratio sorted! Anywhooo, fun facts
Jack |
Instead of flight modes I use the left slider to dial-in the flaps on my planes. It lets me pick the right amount while in flight and I don't need to grab a switch. If I'm coming in to hot or slow I can make fine adjustments easily.
Like everyone else says, in your radio slow down the deploy (down) side of the flaps (I have mine close to 3 seconds) and deploy them when flying slow and you won't get any pitching up. And like everyone else, I refused to believe how slow the the Electra will go. In fact I refused to fly at my normal field (400 feet) because I thought I needed more room. But I found out last weekend, 400 feet is more than enough. My suggestion on the maiden would be to take it up fairly high, point it into the wind, deploy the flaps and turn off the motor. Let it slow down until it stalls and you will see how slow it will go. Stalls are uneventful, slow, predicable and always straight forward, no wing dips. Good luck!! |
Thanks, I will look into using the flap switch for flight modes, never heard of that but my radio does have an elevator trim mode mixed into the flaps. I did slow the flap servo and as a full scale pilot I know to slow before deploying them I have been fortunate to watch Jack D fly his Electra many times and it is pretty wild how it can slow down. I put brakes on mine as my regular field is also 400 feet but after watching Jack I realized I did not need them. LOL
Jack |
Thread Tools | |
Similar Threads | |||||
Build Log | BVM Electra ARF build and modifications | ralf dvorak | Electric Ducted Fan Jet Talk | 44 | Jun 10, 2017 09:53 PM |
Discussion | BVM Electra ARF | Kevin Murray | Electric Ducted Fan Jet Talk | 26 | Jun 12, 2014 08:13 PM |
Discussion | BVM electra/Air blue gear. | skyhawk | Electric Ducted Fan Jet Talk | 0 | Apr 25, 2011 05:55 PM |
For Sale | BVM Electra ARF (RTF) - $4200 | chw757s6640 | Aircraft - Electric - Jets (FS/W) | 11 | Mar 12, 2011 10:01 PM |
For Sale | BVM Electra ARF coupon | RicVaughn | Aircraft - Electric - Jets (FS/W) | 0 | Oct 09, 2008 08:43 PM |
