Tarot GY650 MEMS Gyro - RC Groups
May 09, 2011, 12:12 AM
as much as I can
beenflying's Avatar
Tarot GY650 MEMS PID Gyro - Analog and digital servos supported
There doesn't seem to be much online about this gyro, but what little there is looks good and I can't find any bad.
Here's what I've found so far:
The manual:
http://www.cnchelicopter.com/0120201...ser_manual.pdf
Seems to have a lot of the programming features.
Here's a couple of videos:
TAROT 450 GY650 (1 min 12 sec)
tarot gy650 & GOTECK GS D9257 (5 min 19 sec)
Here's what you get:
Description:
Description:
Description:
Some specs:
Description:
Price: $49.98 shipped (eBay)
I've got one coming, so standby for an honest opinion.
If anyone already has one, please feel free to post about it here.
May 09, 2011, 07:03 PM
as much as I can
beenflying's Avatar
Some more videos of the GY650 in action:
http://v.youku.com/v_show/id_XMjM2NDQ5OTI4.html
http://v.youku.com/v_show/id_XMjM2NjEyNDQ0.html
I also found out the same gyro is call a Robird G20. Here's the manual for the G20:
http://www.robirdrc.net/files/20101230113755.pdf
Web site:
Here's a video of a G20 in action:
http://v.youku.com/v_show/id_XMjYwMDE1MjEy.html
Setup:
http://v.youku.com/v_show/id_XMjQ4Njk5MTQ4.html
Looks good. Especially the piro rate, which seems very consistent.
May 09, 2011, 07:11 PM
as much as I can
beenflying's Avatar
From Robirds site (translated):
G20 gyro video
G20 public testing for some time, and because some of our internal reasons, there has been no model in the open market and the majority of faithful met. We will be in the market recently launched our G20. G20 gyro is a faithful model for sharing the video. http://v.youku.com/v_show/id_XMjM3OTk2OTQ0.html
Thank you, Friends of the mold to provide the wonderful video, my colleagues also hope to provide the general mode of Friends of the video on our gyroscope. We will announce our official web site available to the general model faithful to share.
May 09, 2011, 10:17 PM
as much as I can
beenflying's Avatar
It looks like setting up this gyro is a breeze. The bi-color LEDs (blue/red) on the left show the parameter selected and the blue leds on the right show the value from 1 to 5 (5 is the top led).
Here are some simple instructions on how to setup this gyro:
Note:
* First make sure your rudder channel is not reversed. This is set in the gyro now, so the rudder stick will always work the same when programming.
* To enter configuration mode, make sure the helicopter is stationary.
1/ In Headlock mode, hold the rudder stick to the left for 3 seconds.
- The leds will dance and then the top left blue led will flash.
- This indicates that the current parameter displayed is the Servo Type.
- The leds on the right display the current value, which defaults to 3 (1520/280).
2/ To select the parameter, briefly push the rudder stick to the left or right.
3/ To change a parameter, hold the rudder stick to the right for 2 seconds.
- The parameter selected on the left will light solid and the parameter value on the right will now flash.
4/ To change the parameter value, briefly push the rudder stick to the left or right.
- Remember the top led is value 5 and the bottom is value 1.
5/ To save the new parameter value, hold the rudder stick to the right for 2 seconds.
6/ You can now select another parameter, if required.
7/ To exit configuration mode and return to flight mode, hold the rudder stick to the left for 3 seconds.
Note:
* If "leave configuration state" works by holding the rudder stick to the left, reverse the rudder in the TX.
* The direction parameter has 4 options to allow reversing the gyro and the servo. Don't reverse the channel in the TX for this.
* The limit parameter is interesting. When selected the limit is set by moving the helicopters tail until the servo is at the limit and then holding the rudder stick to the right for 2 seconds to save it. Repeat again to do the opposite limit. It doesn't appear to matter in what order the inner and outer limit is set.
Parameters:
1 - Servo type (5 options)
2 - Direction (4 options)
3 - Limit
4 - Left brake (5 options)
5 - Right brake (5 options)
6 - Piro rate (5 options)
7 - Expo (5 options)
8 - Sensor response (5 options)
9 - Lock gain (5 options)
Now $47.88 shipped (ebay)
May 10, 2011, 05:48 AM
Standing by for a review and any vids..
May 10, 2011, 03:19 PM
Looptastic!
sp00fman's Avatar
I think i want one. Thanks for the info!
May 10, 2011, 09:43 PM
as much as I can
beenflying's Avatar
Glad I could return the favor. Thanks to your posts, my current build is the Gaui 425.
May 11, 2011, 02:17 AM
Looptastic!
sp00fman's Avatar
sweet dude. your gonna love it!
May 11, 2011, 11:36 AM
anarchist
frac's Avatar
whatever is responsible for those translations needs to be blown off the face of the earth
May 12, 2011, 06:54 PM
Skint since 2000
ghost2212's Avatar
Just bought one of these
Just picked one of these up on ebay and will post my thoughts once its arrived. I'll test it initially on a 450 but could try it on a 250 as well
May 12, 2011, 11:28 PM
as much as I can
beenflying's Avatar
Good one, ghost2212! Looking forward to hearing how you get on.
My ones going in a Gaui Hurricane 425 (T500 size heli).
May 13, 2011, 07:31 AM
Skint since 2000
ghost2212's Avatar
Hopefully soon i'll also be getting a Trex 550 with a BeastX so i can compare it to the tail gyro on that, As of yet i havent flown a decent gyro so it will be interesting,unless you count the sim
May 13, 2011, 07:45 AM
as much as I can
beenflying's Avatar
Nice! I really like my Trex 550E 3G. It just ticked all of the boxes for a perfect heli for me.
Have you also looked at the Gaui X5 FES. Seems like a really nice heli as well:
http://www.infinity-hobby.com/main/p...oducts_id=6725
May 13, 2011, 08:08 AM
Skint since 2000
ghost2212's Avatar
I have seen that but its a bit smaller I believe as the 550 can swing 550blades from what ive read even though it comes with 520's. The X5 comes with 500mm blades. Spares availability is not as good for the gaui where as most good heli shops sell align. The price looks a bit cheaper at 900$ but thats still 600 and when you add 20% Vat it comes to about 720+ whatever stupid customs might add on. The 550 is about 650 here in the uk plus 150 for the beastX and its maybe a tiny bit more expenive but its from the UK.
Anyway back on topic
when are you expecting yours to arrive?
May 13, 2011, 08:22 AM
as much as I can
beenflying's Avatar
Sounds like the 550 ticks more of your boxes as well.
I ordered mine the same day I started this thread, but with Hong Kong post, it's anyone's guess. Hopefully next week...
Discussion Help with setting up ga-250 mems gyro captaintomo Electric Heli Talk 2 Mar 09, 2011 05:48 PM
Alert Spartan Quark - MEMS AVCS Gyro V2.02 $99.99! kctrading Hot Online Deals 4 Apr 19, 2010 07:13 AM
Discussion tons of gyro modules!!! very small MEMS gyros drex Product Announcements 0 Aug 13, 2009 10:18 AM
Question MEMs gyro accuracy BarrelRoll UAV - Unmanned Aerial Vehicles 8 Oct 26, 2007 09:06 AM
