May 05, 2011, 04:19 PM
Air Cooled VW mechanic
THX-181's Avatar
Help!
64mm shroud vibrating in a flat foamie
I have a TechOne SU-27 flat foamie with a 64mm edf.
The edf housing is only attached to the airframe at two points.
At a specific rpm the edf housing resonates badly and contacts the impeller.
I'm tempted to cut out a couple light ply ring segments to glue to housing.
Am I on the right path?
Is this a common issue?
Eric
May 05, 2011, 06:21 PM
JGuilty13's Avatar
Just sounds like your fan in unbalanced....pretty common especially if its a stock unit. A lot of my edfs will resonate at a certain RPM, but usually goes away when I exceed or decelerate.
May 05, 2011, 08:38 PM
Aka: Tom Jenkins
ApexAero's Avatar
Try and rotate the impeller a few degrees on the shaft at a time, recheck untill you hit the sweet spot
May 05, 2011, 08:57 PM
Indoor Free Flight Modeler
If you can remove the motor fan unit, I offer dynamic balancing services for a fee. It will run very smooth afterwards.
Don
May 06, 2011, 01:30 AM
THX-181's Avatar
Thanks for the advice.
I did balance the impeller.
In this case i can actually watch the the housing deflect inward towards the impeller at a specific RPM.
Any other ideas?
May 06, 2011, 05:46 AM
D_FAST's Avatar
If it is your shroud defleting. Get ahold of some CF strands/tape/mesh and epoxy this around the shroud to beef it up.
Take a look at how guys use the CF tow strips to beef up the glassed intakes. same method same purpose.
For Sale Misc 70mm Fan/Shroud/Motor setups $20 shipped each SkylineFlyer Aircraft - Electric - Jets (FS/W) 6 Aug 06, 2011 07:33 AM
Help! 2.4 Rx placement in foamie fuselage rhysduk Radios 4 Mar 18, 2011 04:12 PM
Mini-Review 64mm SF Shroud, 64mm RClander rotor, and HET 2W-20 motor zach_dad Electric Ducted Fan Jet Talk 2 Jun 12, 2010 10:04 AM
Data 64mm EDF TEST Hoaye Rotor, eflite shroud, and HET 25 motor zach_dad Foamy EDFs 4 Feb 07, 2010 08:29 AM
Wanted Ds- 75 shroud or any 110 mm shroud Getmore Rc Aircraft - Electric - Power Systems (FS/W) 1 Jul 08, 2009 06:21 PM
