May 04, 2011, 04:26 AM
2 Gyros on board + 1 Gyro standalone (KK inside)?
Hi,
After a crash of my KKCopter one HK gyro died.
I bought a new one but the components inside changed.
So I have now 2 old HK Gyros + one new. They can't be mixed on the same board.
Can I use the 2 onboard gyros for Pitch and Roll and one external (between Rx and board) for the Yaw?
Is it possible? If yes do I leave the slot for the yaw gyro on the board empty and that's it or do I have to solder some tracks?
Thanks for the help.
May 04, 2011, 02:05 PM
Help?
Aug 11, 2011, 03:02 PM
I have the same problem, The Yaw gyro sub assembly was damaged , any idea of recovery?
Aug 11, 2011, 10:23 PM
I have used a kk board with no hk401 yaw module and flew fine but it was troublesome to setup. Removed yaw module completely and flashed board with xx11a software that had the no_yaw_gyro defined and recompiled. Then placed a GY250 gyro between the rx rudder out and kk board input. Set the endpoints up on the gyro so there was enough rudder "travel" that the board would arm and disarm. Control felt slightly different but flew ok. The first person I know of to try the external gyro and get it to work was member "alll" and I simply followed what he did.
Aug 12, 2011, 04:25 AM
maybe you can consider replacing to a new board and possible the price still cheaper than Hacking the Gyro from HK401.
https://www.rcgroups.com/forums/show....php?t=1445151
Wanted eflite 3 in 1 or 2 in1 and gyro for cp pro wanted bigdogrod Aircraft - Electric - Helis (FS/W) 6 Apr 22, 2019 07:39 PM
Wanted phoenix sim, 3 in 1 for cp pro, or 2 in 1 and gyro bigdogrod Aircraft - General - Miscellaneous (FS/W) 2 Mar 15, 2011 12:35 PM
Discussion What gyros to use on a 2 Axis camera gimbal? Voguna Aerial Photography 0 Mar 13, 2011 11:51 AM
Found MCX 5 in 1 board (I have 2 servos, bad gyro) John Boy Aircraft - Electric - Helis (FS/W) 4 Dec 16, 2009 09:13 PM
Discussion Power Source for Standalone Gyro on gimbal? killerforhire Aerial Photography 1 Jul 23, 2009 12:05 AM
