Apr 11, 2012, 08:37 AM
Find my codes here: http://hk.rc-international.info/swarm/sibianul (valid until April 25, 2012)
ZIPPY Compact 3700mAh 3S 35C Lipo Pack Save US$: 26.57
Insta-Cure Super Thin CA 1. oz Save US$: 1.04
BMS-20315 Metal Gears for BMS-380MAX & BMS-385DMAX Save US$: 0.51
Carbon Fiber Tube (hollow) 12x750mm Save US$: 0.60
Turnigy 3A UBEC with Low Voltage Buzzer Save US$: 1.58
2.4Ghz 7DB Antenna for FrSky Modules (And compatible Radios/Modules) Save US$: 4.62
Un-Cure CA Debonder 1. oz Save US$: 0.59
Insta-Flex Flexible Thin CA 1. oz Save US$: 1.10
M3X10 Nylon Screws (10pcs/bag) Save US$: 0.19
M3x12mm Nylon Screws (10pcs/bag) Save US$: 0.23
M3 Nylon Nut (10pcs/bag) Save US$: 0.17
2mm Gold Connectors 10 pairs (20pc) Save US$: 0.66
Turnigy Pure-Silicone Wire 16AWG (1mtr) BLACK Save US$: 0.61
Turnigy Pure-Silicone Wire 16AWG (1mtr) Red Save US$: 0.61
Slow Fly Electric Prop 11x4.7SF RH Rotation (4 pc) Save US$: 0.53
Turnigy Heat Shrink Tube 25mm Transparent (1mtr) Save US$: 0.18
Simple Prop Balancer Save US$: 0.50
Turnigy Pure-Silicone Wire 18AWG (1mtr) Red Save US$: 0.79
Turnigy Pure-Silicone Wire 18AWG (1mtr) Black Save US$: 0.59
4mm Gold Connectors 10 pairs (20pc) Save US$: 0.51
Hard Steel Tweezer Set Save US$: 0.29
X-BLADE Spare SK-5 Steel blades (10pcs/set) Save US$: 0.63
Flat 26AWG servo wire 1mtr (R/B/W) Save US$: 0.15
Twisted 22AWG servo wire 1mtr (R/B/W) 22AWG Save US$: 0.67
FrSky TEMS-01 Telemetry Temperature Sensor Save US$: 0.94
Turnigy Battery Strap 330mm Save US$: 0.37
Battery Velcro Strap (2pcs/bag) Save US$: 1.30
Turnigy 4mm Heat Shrink Tube - BLACK (1mtr) Save US$: 0.31
Turnigy 4mm Heat Shrink Tube - Save US$: 0.31
Turnigy 6mm Heat Shrink Tube - BLACK (1mtr) Save US$: 0.28
Turnigy 6mm Heat Shrink Tube - Save US$: 0.22
5.6mm x 36mm M3 Nylon Threaded Spacer (10pc) Save US$: 0.87
5.6mm x 30mm M3 Nylon Tapped Spacer (10pc) Save US$: 0.88
Turnigy Heat Shrink Tube 50mm Blue (1mtr) Save US$: 0.50
Apr 11, 2012, 08:47 AM
rc grave yard
bradh79's Avatar
turnigy monster beatle
110BS-30985 Spur Gear - 110BS, A2029 and A2035 $0.61
https://www.hobbyking.com/buddy.asp?c...2-4A4C22909A23
110BS-30971 2pc Motor Pinion (15T) - 110BS, A2029 and A2 $1.51
https://www.hobbyking.com/buddy.asp?c...6-A75FD732CF0C
110BS-32007 Diff.Pinion Gear B 2(long) and Outdrive - 11 $0.67
https://www.hobbyking.com/buddy.asp?c...5-221E3FF981FA
Apr 11, 2012, 10:19 AM
Pro RC Boneyard Developer
teknokraze's Avatar
Eliminate receiver grey-outs. Maintain proper voltage to your receiver with a Voltage Protector. Simply plug into any spare servo spot in your receiver to use:
Reg: $4.55
Buddy Price: $1.99
https://www.hobbyking.com/buddy.asp?c...E-350599FF3267
Apr 11, 2012, 10:39 AM
Turnigy 4000 2S DX8 Transmitter Pack in Stock !!
https://www.hobbyking.com/buddy.asp?c...9-F1CC06B85F0E
Apr 11, 2012, 11:37 AM
Sky Pilot
still4given's Avatar
Buddy code for servo Tester
Here is a buddy code for a servo tester
https://www.hobbyking.com/buddy.asp?c...0-B8DA3EC804F4
Should be good until about 4-24-12
Apr 11, 2012, 12:16 PM
Find my codes here: http://hk.rc-international.info/swarm/hfb (valid until April 24, 2012)
Turnigy Be Found Lost Model Beeper Save US$: 0.71
Apr 11, 2012, 01:11 PM
Find my codes here: http://hk.rc-international.info/swarm/javipons22 (valid until April 24, 2012)
Hobbyking ZYX 3-Axis Flybarless System Save US$: 6.00
Apr 11, 2012, 02:50 PM
2spiky's Avatar
C2020 Micro brushless Outrunner 3500kv (11g) Normal price: $16.95 / Buddy price: $8.05 !!!
Turnigy 1440A Servo 4.4g/0.8kg/.10sec (V2) Normal price: $3.39 / Buddy price: $2.87
Rhino 360mAh 3S 11.1v 20C Lipoly Pack Normal price: $6.69 / Buddy price: $3.55 !!!
Turnigy nano-tech 160mah 1S 25~40C Lipo Pack (Kyosho, E-flite, Parkzone Etc) Normal price: $1.37 / Buddy price: $1.06
GWS EP Propeller (DD-4540 114x102mm) (6pcs/set) Normal price: $2.79 / Buddy price: $2.29
GWS EP Propeller (DD-4040 102x102mm) (6pcs/set) Normal price: $2.79 / Buddy price: $2.29
GWS EP Propeller (DD-4025 102x64mm) (6pcs/set) Normal price: $2.60 / Buddy price: $2.14
Apr 11, 2012, 05:23 PM
valid until 26.4.2012 from DE Warehouse !
save: $ 0,29
https://www.hobbyking.com/buddy.asp?c...A-75BE8E769433
save: $ 0,59
https://www.hobbyking.com/buddy.asp?c...7-3EF3CF9512B4
save: $ 0,41
Apr 12, 2012, 04:59 AM
My buddycodes
XT-60 to HXT 4mm Battery Adapter Lead (2pc)
[S]$3.29[/S] $2.11* (discount 36%, -$1.18)
Clevis With Arms M3 M2xL24mm (5pcs/bag)
[S]$5.99[/S] $5.30* (discount 12%, -$0.69)
Knife Edge Reamer 0.5~18mm
[S]$6.15[/S] $5.77* (discount 6%, -$0.38)
TURNIGY 4pcs hex socket driver set
[S]$4.61[/S] $4.01* (discount 13%, -$0.6)
MPX Connector Male/Female (10pairs/set)
[S]$3.99[/S] $3.67* (discount 8%, -$0.32)
Turnigy Infrared Thermometer (-33 ~ 180Celsius)
[S]$9.99[/S] $9.39* (discount 6%, -$0.6)
HK-500GT Landing Skid (Align part # H50122)
[S]$2.20[/S] $0.98* (discount 55%, -$1.22)
[S]$2.24[/S] $1.95* (discount 13%, -$0.29)
Heli Canopy Rubber Grommet Large (6pcs/bag)
[S]$0.34[/S] $0.25* (discount 26%, -$0.09)
Velocity Stack For 30cc-50cc Gas Engine (Red)
[S]$6.63[/S] $6.22* (discount 6%, -$0.41)
Carbon Fiber Tail wheel set 26cc~30cc Gas Plane
[S]$14.56[/S] $13.66* (discount 6%, -$0.9)
TURNIGY Voltage Protector
[S]$1.99[/S] $0.61* (discount 69%, -$1.38)
TurboThumbs Super Big JR Rocker (1pair) Red
[S]$4.95[/S] $4.67* (discount 6%, -$0.28)
Adjustable Control Horn 3x34mm (5sets)
[S]$2.08[/S] $1.58* (discount 24%, -$0.5)
All my buddy-codes here
Apr 12, 2012, 07:15 AM
Find my codes here: http://hk.rc-international.info/swarm/pavcon (valid until April 26, 2012)
Woven Carbon Fiber Sheet 300x100 (1.5MM Thick) Save US$: 1.32
good for horns
Apr 12, 2012, 10:34 AM
R/C newbie
Find my codes here: http://hk.rc-international.info/swarm/rkovvur (valid until April 22, 2012)
Self Tapping Screws w/shoulder M2x8 (10pcs/set) Save US$: 1.12
Pinion Gear 2.0mm/0.5M 9T (1pc) Save US$: 0.26
Turnigy Servo Tester Save US$: 0.99
Pinion Gear 2.0mm/0.5M 11T (1pc) Save US$: 0.24
Apr 12, 2012, 04:29 PM
Find my codes here: http://hk.rc-international.info/swarm/chilaspt (valid until April 18, 2012)
HK450V2 Main Shaft Save US$: 2.04
HK-450 Metal Tail Rotor Shaft upgrade version (HS1203) Save US$: 0.18
HK450V2 Stabilizer Bar Save US$: 0.63
HK450V2 Tail Blade Save US$: 0.39
HK450V2 Timing Belt Save US$: 0.37
HK450V2 Stabilizer Blade Save US$: 0.51
HK450V2 Metal Tail Boom Holder Save US$: 0.71
HK450V2 Landing Skid Save US$: 0.85
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 11 Feb 15, 2014 04:26 PM
Discussion what do you use as umbilical cable to your ROV? fluxno ROV - Remotely Operated Vehicles 3 Apr 01, 2011 10:46 AM
Discussion Do you wish (When you started) there were as many choices Bryce.R Electric Heli Talk 0 Jan 09, 2007 05:40 AM
Cascade Charger that will charge your battery automatically as many packs as you wish cadetman Batteries and Chargers 8 Feb 08, 2005 03:12 AM
