Charging AGM Batteries with PowerLab8 - RC Groups
Apr 16, 2011, 03:29 PM
I'm purchasing an ODYSSEY AGM battery PC1500 (or the Sears equivalent) to power my sailplane winch. On the Odyssey web site they recommend using a charger that can bulk charge at 25 amps or more and includes the following three phases:
  • Bulk Phase - Fast charges the battery up to 14.7V and gets the battery to about 80% state of charge.
  • Absorption Phase - Finishes off the charge in no more than an additional 4 to 6 hours after completion of bulk charge.
  • Float Charge
More details can be found here - http://www.odysseybatteries.com/acce...er-charger.htm
and here on page 13 - http://www.odysseybatteries.com/files/techbook.pdf
This technical document goes into pretty good detail. You can see a summary of the charging profile on page 12 in Figure 6.
Seems to me my PowerLab8 should be able to handle this easily but I don't see any presets for AGM batteries and I've really not learned how to use the more involved functions. Additionally, I've read that AGMs require different charging profiles from old style Pb batteries but I don't really understand what those differences are.
If anyone can share some experience with this it would be greatly appreciated.
Thanks!
Louis
Apr 18, 2011, 01:35 PM
President, FMA, Inc.
Tim Marks's Avatar
  • Float Charge
Thanks!
Louis
Hi:
The AGM presets are already in the library of the PL8 V2 Charge Control Software.
1) Click a preset you wish to over-write (or empty preset)
2) File > FMA Default Presets > Open File to Preset #
In the Lead Acid (Pb) folder, you will find the AGM preset you need.
Yes,the AGM preset does conform to all 3 phases you listed in your inquiry.
Tim Marks
Apr 18, 2011, 05:29 PM
Originally Posted by Tim Marks
Hi:
Tim Marks
Hi Tim,
That is really good news. I was all prepared to spend 100 to 200 on a dedicated AGM charger and then realized I should be able to do the same with this. Excelent!!!
Also, can you tell me how v2 has changed from v1? It sounds like there are hardware changes required to get to the full 40amps.
Louis
Apr 18, 2011, 07:27 PM
Tim Marks's Avatar
Hi Tim,
Louis
Hi:
There are no significant hardware changes between v1 and v2. We upped the input wire gauge a fraction, but we endurance tested on v1 at the full 40A and everything looked good. We DID update the output Stackable Banana cables from 30A capacity to 40A. This would matter if you were trying to charge 1 pack at the full 40A current, but if you are parallel charging 2 or more packs, it is not material.
Tim Marks
Apr 18, 2011, 09:32 PM
Hi:
Tim Marks
The larger AGMs expect 40 amps in the bulk phase so I'd be pushing this at the max. Sounds like it would be reasonable for me to upgrade the wiring.
Louis
Apr 19, 2011, 04:34 PM
Hi Tim, I guess I must of missed it when it was added, but the float charging is a recent addition, correct?
I see it was requested here:
https://www.rcgroups.com/forums/show...0&postcount=19
But wasn't aware it was added.
Apr 19, 2011, 10:35 PM
Tim Marks's Avatar
Hi:
I think the confusion is in my own mind, or maybe I don't fully understand the request. I know the AGM presets float charge, but I think it is part of a 3 phase process. I was under the impression that the request was for a separate "float charge only" feature. Honestly, I'm not sure how or if that is implemented, and so I added the request onto the new features ss to remind me to speak with the chief engineer about it later.
What are your thoughts on the matter? Perhaps we already supply what was requested?
Tim Marks
Oct 23, 2012, 07:28 PM
Going to dig up an old thread here. Just bought an AGM but only have an iCharger 306b right now which has no AGM profile . Am I correct to assume that if the PL8 has an AGM profile the PL6 does as well? The PL6 would meet my needs so if I can save a few $$$ that would be preferable.
Oct 23, 2012, 07:36 PM
Tim Marks's Avatar
Hi:
If you follow the instructions of post #2 from this thread, it'll work the same for PowerLab 6 as for PowerLab 8. The AGM preset is out there in the library.
Tim Marks
Oct 23, 2012, 08:09 PM
Hi:
Tim Marks
Guess I'll be placing an order for a PL6 then. Thanks.
Oct 23, 2012, 08:24 PM
Huh?
Oct 24, 2012, 07:45 AM
Originally Posted by Ohmic
Huh?
You want points for most pointless response ever? I fail to understand how you could be at all confused.
Oct 24, 2012, 08:26 AM
Sorry, Thought you had a PL8 already.
May 06, 2017, 07:22 AM
PL8 Dual
Hi Tim
I have a dual PL8, Version 1.1, and have been through all the menus to try to find the AGM charging. I have also looked through the software. Any chance of sending screen shots so I can charge a deep cycle battery I have.
May 08, 2017, 02:26 PM
Tim Marks's Avatar
Originally Posted by towball
Hi Tim
Hello:
I just replied to your email. Please check it!
Sincerely,
Tim Marks
President
FMA, Inc.
Revolectrix Partner
Discussion charging lipo batteries slower balance better flysohigh Batteries and Chargers 1 Mar 18, 2011 03:35 PM
Discussion Field charging batteries flylite Batteries and Chargers 7 Mar 16, 2011 04:00 AM
Charging nimh batteries with Tekin charger Flyingfool Electric Plane Talk 1 Jul 10, 2002 12:44 PM
Charging nmh batteries with a peak detection charger? Peter Young Electric Plane Talk 4 May 22, 2002 08:59 AM
charging other batteries with a firebird charger?? cheapflyr Parkflyers 0 Apr 26, 2001 06:19 PM
